Kεντρικό ηχείο Crystal Audio...
sakisxas
7 September 2006
5,384
C:\Greece\Komotini
Kεντρικό ηχείο Crystal Audio System Center 4 πωλείται σε άριστη κατάσταση χρώμα κερασιάς.Δέχεται διπλοκαλωδίωση
Τεχνικά χαρακτηριστικά.
Specifications:
Loudspeaker 2-way
Magnetically Shielded
Tweeter Electronically Protected
Woofer 3' Aluminum Concave 4
Tweeter 1" Aluminum Dome
Input Power (Wrms) 100
Max. Power (Watt) 200
Sensitivity (dB/Wm) 92
Nominal Impedance (Ohm) 8
Freq. Response (Hz-kHz) 110-25
Enclosure Type Bass Reflex
Biwire Gold Plated Binding Post
Dimensions (WxHxD mm) 500x112x80
Weight (kg) 5
System Center 4
Center
Slim-line center speaker designed for easy positioning
System Center 4 is a slim-line center speaker designed for easy positioning on top of any TV set or any shelve above or below it.
With very fast transient response and extra smoothness in the high frequencies, System Center 4 is the ideal choice for medium or small sized listening rooms.
Using 4 woofers and 1 aluminum dome tweeter, it reproduces the human voice with great accuracy and warmth. Finally, because of the small size of the woofers, the dispersion is even in all directions.
Available cabinet finishes: Rosewood, Calvados (cherry), Beech, Black Ash, Silver Ash and Silver.
Τιμή 80 ευρώ.
