Killzone 3
sfortis
Administration Team
3 August 2006
11,392
t3.large
H open beta του πολυαναμενόμενου shooter βρίσκεται από σήμερα το μεσημέρι στα ράφια του PSN store.
Περιλαμβάνει τον χάρτη MP05 ‛Frozen Dam’ και τα παρακάτω multiplayer modes. Ιδιαίτερη προσοχή έχει δοθεί στα controls που είχαν φανατικούς lovers άλλα και haters στην προηγούμενη έκδοση του παιχνιδιού, στο framerate όπου είναι αρκετά βελτιωμένο και στα σημεία στρατηγικής όπου έπασχε το προηγούμενο (σταθερά spawn points πχ).
Σύμφωνα με τις πρώτες μαρτυρίες, τα λεγόμενα των developers επιβεβαιώνονται!
Guerrilla Warfare (16 players)
Guerrilla Warfare is a standalone multiplayer mode similar to classic Team Deathmatch: You and your teammates must try to kill as many of the opposing team as you can before the timer runs out. In this mode, only the downstream monitor houses and repair bay are accessible, giving the map a very frantic pace.
Warzone (24 players)
If you’ve played Killzone 2, you may already be familiar with Warzone. It’s a round-based multiplayer campaign that consists of five randomly ordered mini-missions. In this mode the power house and penstocks directly under the dam are accessible as well, so there’s more room to come up with different strategies and approaches to your goal.
Operations (16 players)
Operations is a new multiplayer campaign which aims to deliver a more cinematic, story-based gameplay experience, similar to that of Killzone 3′s single-player mode. It consists of a sequence of linear mini-missions, in which the ISA must try to secure the docks and destroy the dam, while the Helghast must try to protect the dam facility.
Botzone (one player and up to 15 bots)
Botzone is an offline multiplayer mode ideal for those looking to get to grips with the controls, the weapons or the map layout before going up against live players. Each of the aforementioned multiplayer modes can be played offline, against CPU-controlled opponents.
Re: Killzone 3 *open beta*
A network related error has occurred
General server failure. Please check network connection.
Error code -991 & 20002
Δοκίμασε κανείς να συνδεθεί επιτυχώς;
είχε ενα θέμα ο server, μάλλον δεν περίμεναν τόσο κόσμο... χθες μου έβγαλε μια φορά το θεϊκό μήνυμα "error κάτι there is no empty space in this world"
Το παιχνίδι είναι φοβερό. Το θυμάμαι από το ps2 και πιστεύω είναι το καλύτερο shooter.
Η αγορά του playstation move αποκλειστικά για το Killzone 3 αξίζει; Θα έχουμε πλήρεις έλεγχο ή θα χρειαζόμαστε και χειριστήριο;
Θα με καλύψει το playStation move "Sharp Shooter"
Αυτό... μάλιστα, όλα σε ένα!
Πηγή: us.playstation.com
Δεν το βλέπω στην Ευρωπαϊκή αγορά και ανησυχώ...
Edit: Το εντόπισα στο amazon 42 EUR
Λιγο που έπαιξα με move το beta θα ελεγα ότι δεν αξίζει να ασχοληθεις με αγορά περιφερειακών κτλ...
Δεν ξέρω... δεν είναι ότι έκατσα και με τις ώρες να το καλιμπράρω τέλεια, όμως με απλοϊκές ρυθμίσεις που έκανα, η αίσθηση ήταν πολύ ασαφής. Ίσως με σωστή ρύθμιση sensitivity, dead zone κλπ τα πράγματα να φτιάχνουν, όμως επειδή ψιλοβιαζόμουν να φύγω κι ήθελα απλά να δω πως είναι, προσωπικά έπαιξα το demo τελικά με gamepad...
Ιστορία
Η αντεπίθεση ξεκινά εδώ
Πολεμήστε μια ολόκληρη αυτοκρατορία που έχει βάλει στόχο να σας εξοντώσει στο Killzone 3, αποκλειστικά στο PlayStation 3. Μακριά από την πατρίδα σας και με μόλις ελάχιστους συντρόφους να έχουν απομείνει στο πλευρό σου, βρίσκεστε αντιμέτωποι με την υπέρτατη δοκιμασία θάρρους καθώς καλείστε να επιβιώσετε σε αντίξοες συνθήκες που τσακίζουν και τα πιο γερά νεύρα.
Καθοδηγείτε τον Tomas "Sev" Sevchenko, πιάνοντας το νήμα της ιστορίας ακριβώς μετά τα απίστευτα γεγονότα του Killzone 2. Με τον αυτοκράτορα Visari των Helghast νεκρό στα πόδια σας, δεν γίνεστε μάρτυρας της κατάρρευσης της αυτοκρατορίας του, αλλά αντίθετα παρακολουθείτε μια μαζική εξέγερση καθώς επιθετικά σκάφη και ορδές στρατευμάτων ενώνουν τις δυνάμεις τους για να σας καταδιώξουν.
Ο στόχος σας είναι να επιζήσετε και να διαφύγετε. Άλλο όμως να το λες και άλλο να το κάνεις. Πρέπει να περιηγηθείτε στην ισοπεδωμένη από την πυρηνική καταστροφή πρωτεύουσα Pyrrhus και να αναμετρηθείτε με τον πιο αμείλικτο εχθρό που εμφανίστηκε ποτέ στο PlayStation: τους Helghast.
Ενώ εσείς μάχεστε για την επιβίωσή σας, οι Helghast "τρώγονται" μεταξύ τους. Στη μάχη επικών διαστάσεων που εκτυλίσσεται στους διαδρόμους της εξουσίας στην πρωτεύουσα Pyrrhus, η στρατηγική των Helghast περιλαμβάνει από την ωμή βία του Ναύαρχου Orlock έως τις μηχανορραφίες του Προέδρου Stahl που είναι επικεφαλής ενός τρομακτικού οπλικού προγράμματος. Ωστόσο, οι έριδες των Helghast το μόνο που καταφέρνουν είναι να εξαγριώνουν ακόμα περισσότερο τους στρατιώτες που σας κυνηγούν.
Εάν δεν προσαρμοστείτε, το τέλος είναι σίγουρο. Μόνο αν στρέψετε τα όπλα και την τακτική των Helghast εναντίον τους έχετε ελπίδες να ξεφύγετε ζωντανοί από τον πλανήτη.
Ενώ το σενάριο αναφέρεται στην απεγνωσμένη προσπάθεια επιβίωσης που καταβάλλετε εσείς και οι αποδεκατισμένοι σύντροφοί σας, το σύμπαν του Helghan προσφέρει την απόλυτη οπτική απόλαυση. Θα περιηγηθείτε σε παγωμένους ερημότοπους, στο ζοφερό σκηνικό της πρωτεύουσας Pyrrhus, σε ζούγκλες με εκτυφλωτικά χρώματα, σε μια απέραντη χωματερή, ακόμη και στην καρδιά της πολεμικής μηχανής των Helghast.
Πηγή: gr.playstation.com
Άκρως εθιστικό!
Χρόνια είχα να παίξω τόσο εθιστικό παιχνίδι πρώτου προσώπου, το single-player campaign διαρκεί περίπου 6 ώρες.
Αύριο θα παραλάβω το "Sharp Shooter" :D
είμαι στην αρχή του campaing και είναι καταπληκτικό!
τα γραφικά είναι απλά εκτός ανταγωνισμού και κάνει όλα τα άλλα κονσολο-fps να φαίνονται παιδικά.
το multiplayer με κούρασε λόγο της campero-κατάστασης με τους αόρατους snipers, Ιnfiltrators και τις παραφορτωμένες με γραφικά πίστες.
