ΝΕΑ ΤΙΜΗ ! Kodak 605 Professional Photo printer
Νεα τιμη: 600
Printer specifications
Printing process Thermal dye sublimation
Image quality Continuous tone, 300 dpi
Print time: 11 sec. for 10x15 cm (4x6-in)
18.5 sec. for 13x18 cm (5x7-in)
18.5 sec. for15x20 cm (6x8-in)
Maximum imageable area: 10x15 cm borderless (4x6-in)
15x20 cm borderless (6x8-in)
Media capacity: 750 -10x15 cm (4x6-in) prints (106 7347)
EKTATHERM 4R Print Kit
375 - 13x18 cm (5x7-in) prints (189 9160) EKTATHERM 5R Print Kit
375 - 15x20 cm (6x8-in) prints (197 4096) EKTATHERM 6R Print Kit
Computer interface USB 2.0 and USB 1.1
Physical dimensions 290 mm x 498 mm x 326 mm
(11.4-in W x 19.6-in D x 12.8-in H )
Weight: 18 kg (40 lbs.) (without ribbon or paper)
Operating temperature +15 to +35°C (59 to 95°F)
Relative humidity 20 to 80%
Power consumption 320 watts maximum
Printer drivers and software WINDOWS 2000 and WINDOWS XP OS
PC minimum specifications Personal computer with
WINDOWS 2000 or WINDOWS XP
WINDOWS 2003 Server, or WINDOWS VISTA Operating System
Operating System Minimum 1.0 GHz PENTIUM III CELERON microprocessor
Minimum 256 MB RAM; 2 GB of available hard disk space
(Note: You may need up to 256 MB of RAM and 10 GB of hard disk space for acceptable performance with some imaging applications on high performance, multi-tasking operating systems)
USB High Speed (2.0) compliant host device
