"Κρυφοί πομποί" σε Hot Bird!
Voreios
18 January 2007
4,750
Αντιγραφω απο το sat-television.com αν καποιος γνωρίζει περισσότερα ή έχει το εξοπλισμό για λήψη ας αναφέρει:
Three „hidden” transponders at 13E
* 2009-06-30 01:23:05 / Mr. Orbita
* last update: 2009-06-30 18:05:16
* source: satkurier.pl
It turns out that the number of free transponders at 13°E is smaller than widely known. Italian broadcaster Mediaset uses three frequencies on Hot Bird 9 (13°E) satellite providing channels in DVB-S2 modulated in 16APSK, this is the reason why most of digital receivers cannot receive this transmissions. It is interesting that these three transponders are excluded from digital channels tables in most popular services providing them. We have managed to confirm a reception of a „hidden” transmissions in DVB-S2/16APSK from 13°E!
At this time, we can confirm receiving of 16APSK signals from 13°E with three devices. We had the most stable signal on Prof Revolution Series DVB-S2 7301 DVB card. After channel search it showed correct channel names with full technical parameters. We also found two receivers that can successfully find signal and search channels: Maximum TS-3000 CX-CI and Vantage HD 8000 S PVR Twin (second receiver was much less stable and needed few attempts to correctly search channels with their names).
None of these three devices can directly receive 16APSK modulation, because signal is not stable. Picture and sound on FTA channels from these frequencies is disrupted.
It is very curious that even Eutelsat in tables of digital channels transmitted over their satellites, which are published on its website, omits three transponders from which Mediaset is transmitting channels in DVB-S2/16APSK. What could be the reason for hiding Mediaset channels and not confirming these transmissions?
Technical parameters of all channels (PIDs are given in format: Video/Audio/PCR/SID):
tp. 7 (11.334 GHz, pol. H, SR: 27500, FEC: 2/3)
Canale5 HD (1010/1011/1010/5305; MPEG-4/HD)
Cartoon Network - Premium (410/411/410/157)
Diretta Calcio 1 (490/491/490/102), if there is no transmission - FTA infocard PID V: 630
Diretta Calcio 2 (500/501/500/103), if there is no transmission - FTA infocard PID V: 630
Diretta Calcio 3 (510/511/510/104), if there is no transmission - FTA infocard PID V: 630
Diretta Calcio 4 (520/521/520/105), if there is no transmission - FTA infocard PID V: 630
Diretta Calcio 5 (530/531/530/106), if there is no transmission - FTA infocard PID V: 630
Diretta Calcio 6 (540/541/540/107), if there is no transmission - FTA infocard PID V: 630
Disney Channel +1 - Premium (400/401/400/160)
Hiro - Premium (390/391/390/156)
Italia1 HD (1020/1021/1020/5306; MPEG-4/HD)
Moto GP - Premium (560/-/560/152; FTA infocard)
Playhouse Disney - Premium (380/381/380/158)
Premium Attivazione (470/471/470/130), also with name Premium Menu (SID: 129)
Premium Calcio 24 (480/481/480/101)
Premium Extra (550/-/550/119; FTA infocard)
Steel +1 - Premium (960/961/960/166)
An example of receiving FTA infocard Diretta Calcio with Prof Revolution Series DVB-S2 7301 DVB card
Some data channels and additional identificators with copied PID Values can be found at this frequency. All channels are encrypted in Nagravision 3 (CAID: 1802, 1804 and 1805) except of HD channels, which are encrypted in Seca MediaGuard 2 (CAID: 0100 ProvID: 000B).
tp. 9 (11.373 GHz, pol. H, SR: 27500, FEC: 2/3)
This frequency is active, but signal is too unstable to get channel names. In best case we have found 21 no name services.
tp. 12 (11.432 GHz, pol. V, SR: 27500, FEC: 2/3)
BBC World (590/591/590/155; FTA)
Boing (740/741/740/145)
Canale5 (650/651/650/4005 and 710/711/710/141 with name CANALE 5)
Canale5 +1 (600/601/600/4105)
Class News (570/571/570/153)
Coming Soon (580/581/580/154; FTA)
Iris (780/781/780/146)
Italia1 (660/661/660/4006 and 720/721/720/142 with name ITALIA 1)
Italia1 +1 (610/611/610/4106)
Rete4 (670/671/670/4004, also with name Retequattro and on different PIDs 730/731/730/143 with name RETE 4)
Rete4 +1 (620/621/620/4104)
At this frequency some data channels and additional identificators with copied PID Values can also be found. All channels are encrypted in Seca MediaGuard 2 (CAID: 0100 ProvID: 000B).
Similar transmissions in DVB-S2/16APSK Mediaset provided by Atlantic Bird 3 satellite (5°W) on two transponders:
tp. KB6 (11.677 GHz, pol. V, SR: 27500, FEC: 2/3)
Disney Channel - Premium (890/891/890/109)
Joi - Premium (910/911/910/111)
Joi +1 - Premium (940/941/940/114)
Mya - Premium (920/921/920/112)
Mya +1 - Premium (950/951/950/115)
Premium Cinema (970/971/970/117)
Rete4 HD (1030/1031/1030/6304; MPEG-4/HD)
Steel - Premium (930/931/930/113)
Universal Studio - Premium (1010/1011/1010/118)
At this frequency some data channels and additional identificators with copied PID Values can also be found. All channels are encrypted in Nagravision 3 (CAID: 1802, 1804 and 1805) except of HD channels, which are encrypted in Seca MediaGuard 2 (CAID: 0100 ProvID: 000B).
tp. KA9 (12.585 GHz, pol. H, SR: 27500, FEC: 2/3)
At this frequency some data channels and additional identificators with copied PID Values can be found. All channels are encrypted in Nagravision 3 (CAID: 1802, 1804 and 1805).
It is important to notice that when trying to search we need some patience because sometimes receiver cannot get channel`s names or find all services due to unstable signal. While testing, few attempts will likely be needed to correctly scan all frequencies listed above. Also be aware that not all HD receivers will manage to reveive these transmissions.
This discovery also reveals that there is just one free transponder available at 13°E position - tp. 120 with frequency 10.911 GHz, pol. V. Other transponders are already active or like tp. 112 (10.758 GHz, pol. V) are leased (in this case by Cyfrowy Polsat) and wait for the launch.
Update
After informations from one of our readers we have found another frequency which broadcasting channels in DVB-S2/16APSK. It is available from Atlantic Bird 1 satellite (12,5°W) at frequency 12,718 GHz, pol. H, SR: 36510, FEC: 2/3. There are available following channels (PID V/A/PCR/SID):
AB Channel (6087/-/6087/608; FTA infocard)
cartapiu' (8011/-/8011; FTA infocard)
dahlia 1 adult (2987/2988/2987/47; only at night, in remaining time encrypted infocard PID V: 2992)
dahlia 1 calcio (2967/2968/2967/41; only sport transmissions, in remaining time FTA infocard PID V: 8012)
dahlia 2 adult (2992/2993/2992/48; only at night, in remaining time encrypted infocard PID V: 2992)
dahlia 2 calcio (2972/2973/2972/42; only sport transmissions, in remaining time FTA infocard PID V: 8012)
dahlia 3 calcio (2977/2978/2977/43; only sport transmissions, in remaining time FTA infocard PID V: 8012)
dahlia 4 calcio (2982/2983/2982/44; only sport transmissions, in remaining time FTA infocard PID V: 8012)
dahlia 5 calcio (3002/3003/3002/45; only sport transmissions, in remaining time FTA infocard PID V: 8012)
dahlia attivazione (2997/-/2997/49; encrypted infocard)
dahlia eros (2982/2983/2982/8; only at night, in remaining time encrypted infocard PID V: 2982, turned off when there are any transmissions at dahlia 4 calcio - the same PIDs)
dahlia promo (8009/8010/8009/11; FTA)
dahlia sport (2957/2958/2957/6)
dahlia xtreme (2962/2963/2962/7)
K2-Kids TV (981/982/981/607; FTA)
LA7 (6112/6113/6112/613; FTA)
Mediashopping (640/641/640/70; FTA)
MTV ITALIA (6116/6117/6116/614; FTA)
QOOB (6122/6123/6122/615; FTA)
QVC (6092/-/6092/80; FTA black screen)
Sportitalia (515/680/515/14; FTA)
Sportitalia24 (516/690/516/15; FTA)
TED (700/701/700/140; FTA promo, launch in september)
TIMB HD1 (757/758/757/700; FTA infocard in HD/MPEG-4)
TIMB HD1 Infocard
Signal is much more stable than in transmissions from 13E. We have confirmed receiving of this package with Prof Tuners Revolution Series DVB-S2 7301 DVB card. In listing above, if there is no information about encryptions - channel is encrypted in Irdeto 2 (CAID: 0620 i 0662).
__________________
Σε Nagravision 3 θα εκπέμπει η νέα Δορυφορική Πλατφόρμα Tivu Sat με κανάλια της RAI και της Mediaset. Τα HD κανάλια της Mediaset νομίζω δεν θα εκπέπονται από τη Tivu Sat για αυτό και η κωδικοποίηση είναι διαφορετική.
