Kαλώς όρισες στην παρέα μας,
Είμαι οπαδός της Sharp, ωστόσο για να είμαστε δίκαιοι καλό είναι να πάς να δείς τις τηλεοράσεις που θέτεις και να βγάλεις μόνος τα όποια συμπεράσματα σου.
Παρακατώ θα βρείς τα στοιχεία που αφορούν την Sharp
Sharp46" XL1 Series Full HD 1080p LCD with 100Hz, built-in Freeview, 2 x HDMI & PC Input
Product Features:
• 46" 16:9 Wide Screen LCD Television
• Full HD (High Definition) 1080p with 1920x1080 resolution
• Accepts 1080p, 1080i and 720p HD signal formats
• 2 x HDMI (High-Definition Multimedia Interface) Digital Link for superb digital pictures and sound
• Advanced Super View non-reflective LCD panel
• truD-HD processing chip
• RGB Plus - Primary Red, Green & Blue colours are enhanced by two further shades of Red & Green;
• Provides much more natural and realistic colour shades
• Optical Picture Control light sensor measures ambient room light and automatically adjusts backlight levels
• 100Hz double-frame drive recreates images with twice the number of frames;
• Ideal for fast moving images or scenes with motion left to right or top to bottom
• 450 cd/m2 brightness
• 10,000:1 dynamic contrast ratio for extra deep blacks (Panel Contrast 2000:1)
• 176° wide viewing angle
• Fast 4ms response time
• Picture-and-Text
• Integrated Analogue & Freeview Digital Terrestrial tuner (DVB-T)
• Under mounted speakers with 2 x 15W Output
• Surround Sound & NICAM/A2 Stereo
• Auto volume controls equalise volume levels of programmes with various sound sources
• PC Input allows your computer to be connected to your serve as a large-screen monitor for surfing the web
• Connections include: 2 x HDMI, 2 x SCART, 1 x AV In (V/S Video),
• 1 x Component (Y/Pb/Pr) In,
• 1 x C.I. Slot, 1 x PC Input (D-sub 15pin), 1 x AV output (Audio Out, S/PDIF)
• Power Consumption TBC W, less than 1 W standby
• Screen measures (WxHxD) 1137 x 733 x 124.4 mm
• Measures (with stand) 1137 x 796 x 309 mm
• Weighs TBCkg, TBCkg with stand
• Can be wall mounted with optional wall bracket (VESA 600 x400)
• Please note; picture for illustrative purposes only
Supplied Accessories:
Remote Control, Tabletop Stand, Power Cable, User Manual
Useful Information:
XL1E Series is available in 52" & 46" screen sizes
Η πληροφορία είναι από το
Επίσημο site της Sharp
