- 31 July 2007
- 244
Πωλειται η οθονη Sony SDM-HS93,19 ιντσων.Εισοδοι 1xVGA
Τιμη 100 ευρω
Key Features
Monitor Type Flat Panel LCD TFT (Active Matrix)
Size 19 inch
Contrast Ratio 700:1
Max. Resolution 1280 x 1024
Brightness 250 cd/m²
Response Time 25 ms
Dot Pitch 0.294 mm
Color Depth 24-bit (16.7M Colors)
Viewable Picture Size 19 in.
Technical Features
Form Factor Desktop
Synchronization Range - Vertical 48 - 75 Hz
Synchronization Range - Horizontal 28 - 80 kHz
Max. Viewing Angle - Horizontal 170
Max. Viewing Angle - Vertical 170
Native (Recommended) Resolution 1280 x 1024
Dimensions
Height 17.3 in.
Width 18.9 in.
Depth 10.2 in.
Weight 15.7 lb.
Miscellaneous
Power Consumption 36 Watt
Τιμη 100 ευρω
Key Features
Size 19 inch
Response Time 25 ms
Dot Pitch 0.294 mm
Technical Features
Form Factor Desktop
Dimensions
Height 17.3 in.
Width 18.9 in.
Depth 10.2 in.
Weight 15.7 lb.
Miscellaneous
