Logitech Z-5500 Digital
CENTRAL
30 June 2006
1,819
ATHENS
Λόγω αναβάθμισης πωλούνται τα Logitech Z-5500 Digital.Επειδή είναι αγορασμένα από τον Καναδά παίζουν με μετατροπέα τάσης.
Τιμή: 180
• Powerful, distortion-free bass: The new, larger 10-inch long-throw subwoofer driver with flared bass port delivers 188 watts of thunderous bass.
• Innovative driver technology: Polished aluminum phase-plug satellites combine two drivers into one--the clarity of a tweeter with the richness and fullness of a separate mid-range.
• Digital equalization: The Z-5500 Digital actively adjusts frequency response in real time for the cleanest, most accurate sound reproduction.
• DTS® 96/24 support: Enjoy studio-quality sound thanks to the Z-5500's support for 96 kHz / 24-bit digital audio streams
• Amazingly powerful controls: The Digital SoundTouch™ Control Center lets you control volume to all speakers, set inputs, and much more. And the separate wireless remote is great for home theaters and video game consoles.
• Innovative satellite design: Cloth grilles are removable for a pro-audio look. Pedestals rotate for easy wall mounting or desk placement. Center channel can be mounted on wall, above or below monitor.
• Connect to multiple sources: Simultaneously connect 6 audio sources including PCs, video game consoles, and DVD, CD & portable music players…
• Digital LCD: Clear, crisp high contrast display
• Input: Select audio source (optical, coax, or direct)
• Effect: Select digital surround sound effect
• Settings: Adjust parameters of digital surround sound effects
• Mute: Mute the entire system
• Level: Adjust volume, subwoofer, center, and fader levels
• Pro-audio style knob: Oversized, weighted control knob with digital precision
• System Power
• Auxiliary input jack: For convenient connection to portable audio devices (CD, MP3, MiniDisc®, etc.)
Αφορά αγγελία φίλου εκτός forum
Επικοινωνία: 6944479911 - ΓΙΩΡΓΟΣ
