Lumagen Radiance XE3D
svellinis
1 January 2008
1,857
Νομος Αττικης
Πωλειται ενας Lumagen Radiance XE-3D σε αριστη κατασταση τιμη 1500 Ευρω δεν με ενδιαφερουν ανταλλαγες .6937306752.
Key Features:
-XE3D outputs rated up to 60Hz for 1080p and up to 72/75 Hz for 1080p on the XE3D+
-18 Video inputs (6xHDMI 1.4), 2xHDMI 1.4 video outputs
-18 audio inputs (HDMI inputs are Dolby TrueHD/DTS-HD capable), 2 coax audio outputs
-10 bit processing
-Proprietary Lumagen NoRing™ scaling
-Per-pixel SD/HD video deinterlacing
-125 point (5x5x5) gamut correction -Extensive support for anamorphic lenses
-Supports complete processing of 2D or 3D sources
-Adaptive diagonal filtering
-MPEG mosquito and block artifact reduction
-Temporal noise reduction for SD/HD sources
-2:2,3:2,3:3 pulldown for SD/HD film sources
-Output resolution from 480p to 1080p, plus 1080i
Input configurability:
- Inputs 1-6 are HDMI 1.4 and can be used with HDMI or DVI sources
- Inputs 7-10 are Component (HD/SD)
- Inputs 11-14 are SVideo (NTSC or PAL)
Inputs 15-18 are Composite (NTSC or PAL)
Δεκτη και ανταλλαγη με lumagen xd 3d και 300 Ευρω εαν εχει μαυρη προσοψη ή 450 εαν εχει ασημι
