LyngBox HDTV receiver/recorder
AlexT_
10,461
H LyngBox Media, σε συνεργασία με την LyngSat Network και την European Space Agency δημιούργησαν έναν high definition δορυφορικό δέκτη νέας γενιάς. Η παρουσίαση του έγινε στην έκθεση του Αμστερνταμ IBC 2006.
Αναμένεται να κυκλοφορήσει στις αρχές του επόμενου έτους με τιμή στα 700 περίπου.
Ο διαδικτυακός τόπος που μπορείτε να βρείτε περισσότερες πληροφορίες για τον δέκτη:
http://www.lyngbox.com
Technical Features
  • HDTV support (720p and 1080i)
  • Supports H.264/MPEG-4 AVC and MPEG-2
  • Inbuilt tuners for both satellite TV (DVB-S/DVB-S2) and terrestrial TV (DVB-T)
  • Internal slot system which makes it possible to install an additional tuner card
  • 4:3 and 16:9 TV screen format support and teletext decoding
  • Dual Common Interface slots for usage with pay-TV-channels
  • PVR functionality with inbuilt hard disk
  • Possibilities to store recordings on an external DVD-recorder connected with USB2
  • DiSEqC 1.1 and 1.2 support for controlling LNB and motorised dish
  • Remote control as standard and a wireless remote keyboard as accessories
  • Channel selection by typing the name (or the beginning of the name) of the channel on the keyboard
  • View images from a digital camera connected to the LyngBox
  • The LyngBox can store up to 50000 channels
LyngBox Special Features
  • Free access to all LyngSat Network services (LyngSat, LyngSat Guide and LyngSat Maps) with exclusivity to the LyngBox. No other receiver has access to these services
  • Always corrects channel names, not relying on service names in the DVB stream
  • Family user profiles and parental lock. Each user can have their own selection of channels based on countries, languages and genres which will be updated automatically
Interfaces
  • DVB-S2 input
  • DVB-T input + output (pass-through)
  • Expansion slot for additional tuner card
  • 2 Common Interface slots
  • HDMI-output.
  • Component output
  • Composite output
  • SCART output (RGB and composite)
  • S/PDIF optical output with AC-3 support
  • Stereo audio (2 RCA)
  • 4 USB 2.0 ports
  • Ethernet connection (100BaseT)
Hardware Specifications
  • Size (WxHxD): AxBxC cm
  • STi7100 CPU (three cores: 1x266 MHz, 2x400 MHz)
  • 96 MB System Memory
  • 160 GB Hard Disk
  • OLED front panel display
Guarantee & Warranty
  • The LyngBox has a two years limited guarantee
Στο FAQ της ιστοσελίδας βρήκα και τα παρακάτω:
Is the LyngBox running Linux?
Yes, Linux is used as operating system.
Will it be possible to install new software in the LyngBox?
There are currently no plans to make this possible.
Is cardsharing possible?
No! The LyngBox can only be used for legitimate purposes.
Αν ισχύουν τελικά τα παραπάνω και σε συνδυασμό με το γεγονός ότι δεν έχει ενσωματωμένο card reader, τότε θα αποκλείσει μεγάλη μερίδα υποψηφίων αγοραστών, οι οποίοι στα χρήματα αυτά θα έχουν πιο ευέλικτες επιλογές.
καλάαααααααααααααααα.......
Ας τον ρίξουν στην αγορά πριν τον DM8000 με λογική τιμή και θα τα πούμε τότε!!!!!!
Δεν υπάρχει περίπτωση να μη τον σκαλίσουν τα καλόπαδα (βλ. LINUX)...
Αν είχε και μια σειριακή θα βοηθούσε πραπάνω...
Ναι αλλα ....
The LyngBox supports the so called Common Interface standard. Please check with your local Pay-TV provider if they deliver Common Interface modules together with a Pay-TV subscription upon request.
οπως επισης εχει και Ethernet και USB υποδοχες αρα.....:antlers::antlers:
Mpokera ...υπερεκτιμάς τα καλόπαιδα!
Ενα κλειστο σύστημα είναι πολύ δύσκολο να το ανοίξεις χωρίς να έχεις αναλυτικές πληροφορίες απο τον κατασκευαστή, άλλωστε ...γιατι να το κάνεις αν εκείνος δεν θελει να βγουν ανεπίσημα λογισμικά; Στην πράξη, αυτό που γίνεται στις αλλες περιπτώσεις δεν είναι ότι ...καποια καλόπαιδα αποφασίζουν ξαφνικά να ασχοληθούν με ένα δέκτη...επειδή τους άρεσε, αλλά οι εταιρείες που παράγουν τον δέκτη ΧΡΗΜΑΤΟΔΟΤΟΥΝ ΚΑΝΟΝΙΚΑ τα καλόπαιδα και τους δίνουν οτιδήποτε χρειάζονται απο πλευράς υλικού, κώδικα και πληροφοριών, ώστε να βγάλουν καλά ανεπίσημα λογισμικά για τους δέκτες τους ...για να μπορέσουν να πουλήσουν αυτοί περισσότερο και να πάρουν μεγαλύτερο μερίδιο της αγοράς! Μόνο στην συνέχεια και αφού βγουν τα πρώτα βασικά λογισμικά και ειναι διαθέσιμες όλες οι πληροφορίες μπορει να υπάρξουν ερασιτέχνες που θα γράψουν καποια προγραμματάκια για τους δεκτες που έχουν, η θα ψιλοτροποποιήσουν κάποιο ήδη τροποποιημένο ίματζ...(και τα ανεπίσημα πάνω σε κάποιο επίσημο βασίζονται πάντα)
Ετσι έχουν τα πράγματα, να μην είμαστε αφελείς!
Ως εκ τούτου και με δηλωμένες ξεκάθαρα τις προθέσεις του κατασκευαστή, αποκλείεται να ...σκαλιστεί ο δέκτης!
Απο τι στιγμή που έχει ethernet...όλα τα άλλά είναι περιττά-bye-
Εξήγησε μας λίγο πως και γιατί είναι περιτά!
Και ο ιδιοκτησιακός δέκτης HD του γαλλικού πακέτου έχει εθερνετ, αλλά προφανώς δεν κάνει ...κόλπα!
Αντιθετα υπάρχουν πολλοί άλλοι με εθερνετ που δεν κανεις τιποτε αλλά...έχει προνοήσει ο κατασκευαστής με τα λογισμικά του και τους σερβιτόρους του, αλλά εδώ δηλώνεται επίσημα η αντίθεση του κατασκευαστή σ αυτά!
Είναι απόλυτα φυσιολογικό εφόσον ο κατασκευαστής έχει χρηματοδοτηθεί από την ESA να δηλώνει ξεκάθαρα τις προθέσεις του.
Από την άλλη όμως εξαρτάται τι επεξεργαστή της ST έχει το μηχάνημα. Αν έχει CPU που υποστηρίζεται από το STLinux τότε μπορεί να υπάρξουν ανεπίσημα λογισμικά. Όπως στην περίπτωση του Kathrein...
Ο συγκεκριμένος επεξεργαστής έχει θετικά σημεία..
Αυτό που με προβληματίζει σε αυτόν τον δέκτη είναι το slot που φαίνεται να έχει στο πίσω μέρος. Αν είναι pci, τότε είναι πολλά υποσχόμενος...
Υπάρχει μια γενικότερη παρερμηνεία της θύρας ethernet.
ΔΕΝ κάνουν χρυσά αυγά όλοι οι δέκτες με τέτοια υποδοχή και συνεπώς δεν κάνουν καρτ σεριγκ όσοι την διαθέτουν.
Είναι ένα θέμα που σηκώνει πολύ συζήτηση, αλλά το έχουμε ξαναπεί. Σχεδόν κάθε δέκτης μπορεί να κάνει τον πελάτη είτε μόνος του είτε με τα κατάλληλα συνοδευτικά. Μένουν να εξεταστούν και να αξιολογηθούν η κερδοσκοπική και η χομπίστικη υποστήριξη. Δύο έννοιες αλληλένδετες γιατί πολύ εύκολα η χομπίστικη μπορεί να γίνει κερδοσκοπική.
Πάντως ο Lyngbox δεν έχει έρθει ακομη στην Ελλάδα. Τώρα όλα αυτά που γράφονται ναι μεν είναι σωστά, αλλά όχι και σίγουρα. Και εξηγώ. Με δεδομένο ότι ο lyngbox θα είναι ένα από τα ακριβότερα μοντέλα της αγορας, για να κινηθούν οι πωλήσεις του, εκτός από ωραίο κουτί και δυνατότητες, θα πρέπει να δώσει και ουσία, δηλαδή περιεχόμενο. Μπορεί λοιπόν αν δεν πουλάει ο δέκτης, ο κατασκευαστής να αναθεωρήσει τις απόψεις του και ξαφνικά... να εμφανιστούν καλούδια στο διαδίκτυο... για τα οποία όμως θα αρνηθεί οποιαδήποτε σχέση. Το έργο το έχουμε ξαναδεί, για αυτό καλό θα είναι να περιμένουμε, πριν αρχίσουμε να βγάζουμε συμπεράσματα.
Κατά τα άλλα, από ανεπίσημες πληροφορίες που έχω ακούω ότι ο Lyngbox δεν είναι ακόμη 100% έτοιμος (και δεν εννοώ από πλευράς διάθεσης στην αγορά...)
Εμένα με προβληματίζει κατι άλλο στο πίσω μέρος του δέκτη: Δεν βλέπω βύσματα τύπου F για είσοδο έξοδο σήματος, αλλά όπως τα βλέπω (στην φωτο του λινκ της επίσημης ιστοσελίδας) είναι σαν τα κοινά βύσματα της επίγειας κεραίας! Ελπίζω αυτό να ήταν δείγμα και να μην ειναι έτσι στο κανονικό μοντέλο. Γενικότερα πάντως θα κρίνουμε τον δεκτη όταν τον δούμε και υπόσχεται πολλά στον τομέα των λήψεων που προσωπικά με ενδιαφέρουν (αλλά στην ελλάδα ενδιαφέρουν το 1% των χρηστών, ξέρουμε όλοι τι ζητάει η πλειοψηφία). Η προσωπική μου πείρα πάντως λεει ότι στην αρχή τέτοια μηχανήματα είναι...πάντα ανέτοιμα, αλλά η ποιότητα του hardware (εφόσον υπάρχει) δεν κρύβεται! Εξωτερικά τουλάχιστον αυτός δείχνει για φοβερά high end μηχάνημα!
Πάντως διαβάζοντας το faq βλέπει κανείς αρκετούς περιορισμούς, που δεν ξέρω πόσο θα ενθουσιάσουν!
Can I playback any movie on the LyngBox
The LyngBox can currently only playback movies in the format that it uses for recording.
What is the Ethernet port used for?
LyngBox is uniquely integrated with the LyngSat Network. With a required Internet service, connected to the Ethernet port on your LyngBox, you have unlimited access to automatic channel and program updates. You will also get your support answers thru the inbuilt email client.
Will the source code be made available?
Parts of the source code will be available. Source code based on open source products will be made available. Source code will not be available for proprietary software developed by LyngBox Media or third parties. Source code can be requested by contacting us.
In what format are the programs recorded to the hard-drive and can they be streamed?
LyngBox records movies in its own format, it is planned to enable the streaming of recorded movies from one LyngBox to another.
Παρεμπιπτόντως, στο τμήμα downloads έχει τέσσερα βιντεάκια σε ανάλυση 1280Χ720 (τύπου quicktime mov, H264), διαφημιστικά του LyngBox όπως και παρουσίαση των χαρακτηριστικών του...
http://www.lyngbox.com/downloads/movies/LyngBox-Ad-HD720.mov
http://www.lyngbox.com/downloads/movies/LyngBox-Features-HD720.mov
http://www.lyngbox.com/downloads/movies/LyngBox-Hardware-HD720.mov
http://www.lyngbox.com/downloads/movies/LyngBox-Software-HD720.mov
