Marantz AV 7704
cl7gr
15 April 2008
187
Marantz AV7704 Προενισχυτής Home Cinema 4K 11.2 Καναλιών με HDR και Dolby Atmos, DTS:X και AURO 3D
σε άριστη κατάσταση, αγρατζούνιστος, σε άκαπνο περιβάλλον και με πλήρη συσκευασία.
Τιμή 1100 ευρώ
Marantz AV7704 Specs
Channels11.2Audio FormatsDolby TrueHD, DTS HD Master AudioObject-Based Audio SupportDolby Atmos, DTS:X, Auro-3DSupported File FormatsWMA (non-copyright protected), MP3, WAV, MPEG-4 AAC (non-copyright protected), FLAC, Apple Lossless, DSDDigital-to-Analog Converter (DAC)32-bit AKM
Tuner
TunerAM/FMReception FrequenciesAM: 520 to 1710 kHz
FM: 87.5 to 107.9 MHzSensitivityAM, Effective: 18 μV
FM, Effective: 12 μV (12.8 dBf)
FM, 50 dB, Mono: 2.8 μV (20.2 dBf)Signal to Noise RatioFM, Mono: 70 dB (IHF-A weighted, Direct mode)
FM, Stereo: 67 dB (IHF-A weighted, Direct mode)DistortionFM, Mono: 0.7% (1 kHz)
FM, Stereo: 1% (1 kHz)
Audio
Input SensitivityAnalog: 200 mV
Phono Equalizer: 2.5 mVFrequency ResponseAnalog: 10 Hz to 100 kHz, +1, -3 dB (Direct mode)Signal to Noise RatioAnalog: 105 dB (IHG-A weighted, Direct mode)
D/A Output: 102 dB
Phono Equalizer: 74 dB (A weighting, with 5 mV input)DistortionAnalog: 0.005% (20 Hz to 20 kHz, Direct mode)
Phono Equalizer: 0.03% (1 kHz, 3 V)Rated OutputUnbalanced RCA Pre-Output: 1.2 V
Balanced XLR Pre-Output: 2.4 V
D/A Output: 2 V @ 0 dB playbackTotal Harmonic Distortion (THD)D/A Output: 0.008% (1 kHz, @ 0 dB)Dynamic RangeD/A Output: 100 dBRIAA Equalization Deviation±1 dB (20 Hz to 20 kHz)
Video
Input/Output Level and ImpedanceComposite, Component Y: 1 Vp-p, 75 Ohms
Component PB/CB, PR/CR: 0.7 Vp-p, 75 OhmsFrequency ResponseComposite: 5 Hz to 10 MHz, 0, -3 dB
Component: 5 Hz to 60 MHz, 0, -3 dB
Connectivity
Wi-FiNetwork Type: IEEE 802.11a/b/g/n
Security: WEP 64-bit, WEP 128-bit; WPA/WPA2-PSK (AES); WPA/WPA2-PSK (TKIP)
Frequency Range: 2.4, 5 GHzBluetoothVersion: 3.0 + EDR (Enhanced Data Rate)
Transmission Power: Class 1
Range: Up to 98.4' (30 m) with line of sight
Frequency Range: 2.4 GHz
Modulation Scheme: FHSS (Frequency-Hopping Spread Spectrum)
Supported Profiles: A2DP (Advanced Audio Distribution Profile) 1.2, AVRCP (Audio Video Remote Control Profile) 1.5
Corresponding Codec: SBC
Transmission Range (A2DP): 20 Hz to 20 kHzAirPlayYesAudio Return Channel (ARC)YesHDMI CECYesInputs8 x HDMI (1 x front)
2 x digital coaxial
2 x optical TOSLINK
3 x component video
4 x composite video (1 x front)
7 x stereo RCA (1 x front, 1 x Phono)
1 x 7.1-channel RCAOutputs3 x HDMI
1 x 1/4" (6.35 mm) headphone (front)
1 x component video
2 x composite video
1 x unbalanced 11.2-channel pre-out
1 x balanced 11.2-channel pre-out
1 x stereo RCA zone 2
1 x stereo RCA zone 3Other Ports1 x USB in(front)
1 x setup microphone in (front)
1 x RS-232C
1 x Ethernet LAN
1 x RCA remote control in
1 x RCA remote control out
1 x 1/8" (3.5 mm) IR flasher
2 x 1/8" (3.5 mm) DC 12 V, 150 mA out
1 x ground terminal
1 x FM antenna in
1 x AM antenna in
2 x Bluetooth/Wi-Fi antenna in
1 x AC power in
General
Power Requirements120 VAC, 60 HzPower ConsumptionActive: 60 W
Standby, Network Control and HDMI Pass Through Off: 0.2 W
CEC Standby: 0.5 WDimensions17.38 x 7.38 x 16.25" (44 x 18.5 x 41.1 cm) with antennas down
17.38 x 9.75 x 16.25" (44 x 24.7 x 41.1 cm) with antennas upWeight22.9 lb (10.5 kg)
