Μετατροπή fujinon ebc 50mm f1.4 σε manual αλλαγή διαφράγματος
milaber22
2 December 2012
1,480
Βόλος
Καλησπέρα σας.
Γνωρίζετε αν υπάρχει κάποιος Ελλάδα που να μπορεί να κάνει μια μικρή μετατροπή στον fujinon ebc 50mm f1.4 ώστε να μπορεί το διάφραγμα να αλλάζει χειροκίνητα;
Εδώ έχω βρει κάποιες οδηγίες αλλά δεν τολμώ να το κάνω μόνος μου.
https://www.flickr.com/groups/1170632@N20/discuss/72157622481485064/
Και κάποιες πληροφορίες για το θέμα
[h=3]Hello and thank you for writng. It will be my pleasure to try to help you. Unfortunately, you do not write which camera you are using. Therefore, I can give you only some general information. Because the production of EBC Fujinon lenses was rather expensive due to the glass and special coating used as compared to lenses from other manufacturers, Fujifilm saw to it that their M42 lenses could not be easily used with other cameras. Therefore an Automatic/Manual switch was missing in all Fujinon M42 lenses.
The aperture lever at the back of your lens has to be depressed by the camera (or adapter) so that the aperture will be closed to the aperture stop (f-stop) that you have selected. If you are using your lens with any M42 camera, the aperture will be stopped down when you are pressing the shutter button. Some M42 cameras have an extra lever so that you may stop down your lens before shooting.
If you are using an EBC Fujinon lens such as yours, you will need an adapter with a flange that will always depress the aperture lever. In that case, your lens will work in manual mode. Most M42 adapters for digital cameras nowadays have such a flange for depressing the aperture lever of your lens.[/h]
http://www.pentaxforums.com/forums/...5mm-f1-8-surgery-change-automatic-manual.html
Εναλλακτικά έχω βρει αντάπτορες αλλά δεν ξέρω κατά πόσο θα λειτουργήσουν καθώς ο πωλητής έιχε αφαιρέσει το tab
http://www.ebay.co.uk/itm/121023991840?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
http://www.ebay.co.uk/itm/171018533781?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
εδώ φαίνεται το tab
http://www.fujix-forum.com/threads/adapting-fujinon-m42-lenses-to-x-mount.22570/
Αν δεν παρεμβάλλεται το μεταλλάκι των fujinon, τότε απλά χρειάζεσαι έναν αντάπτορα με "γείσο" το οποίο πιέζει το πινάκι του αυτόματου διαφράγματος και το βάζει μονίμως σε λειτουργία Μ.
