Μια βόλτα σε ανηχοϊκούς θαλάμους
tmjuju
Administration Team
21 January 2007
21,629
Με αφορμή σημερινό άρθρο στο Slashdot http://tech.slashdot.org/story/13/1...h-will-cause-you-to-hallucinate-in-45-minutes
"Industry Tap reports that there is a place so quiet you can hear your heart beat, your lungs breathe and your stomach digest. It's the anechoic chamber at Orfield Labs in Minnesota where 3ft of sound-proofing fiberglass wedges and insulated steel and concrete absorbs 99.99% of sound, making it the quietest place in the world. 'When it's quiet, ears will adapt,' says the company's founder and president, Steven Orfield. 'The quieter the room, the more things you hear. You'll hear your heart beating, sometimes you can hear your lungs, hear your stomach gurgling loudly. In the anechoic chamber, you become the sound.' The chamber is used by a multitude of manufacturers, to test how loud their products are and the space normally rents for $300 to $400 an hour. 'It's used for formal product testing, for research into the sound of different things — heart valves, the sound of the display of a cellphone, the sound of a switch on a car dashboard.' But the strangest thing about the chamber is that sensory deprivation makes the room extremely disorienting, and people can rarely stay in the dark space for long. As the minutes tick by in absolute quiet, the human mind begins to lose its grip, causing test subjects to experience visual and aural hallucinations. 'We challenge people to sit in the chamber in the dark — one reporter stayed in there for 45 minutes,' says Orfield who says even he can't stand the quiet for more than about 30 minutes. Nasa uses a similar chamber to test its astronauts putting them in a water-filled tank inside the room to see 'how long it takes before hallucinations take place and whether they could work through it.'"
http://www.industrytap.com/insanity-or-innovation-the-worlds-quietest-place/11918
http://www.bbc.com/travel/blog/20121022-the-quietest-place-on-earth
http://tcbmag.com/Industries/Technology/The-Quietest-Room-in-the-World-September-2008?page=1
http://www.dailymail.co.uk/sciencet...etest-place-chamber-Orfield-Laboratories.html
παραθέτω μερικά από τα παραπάνω Links , με φωτογραφίες από θαλάμους και ιστορίας ‛τρέλας’ από όσους κατάφεραν να μείνουν μόνοι τους εντός για αρκετή ώρα.
Η αλήθεια είναι ότι αυτό που μου έκανε τεράστια εντύπωση είναι το μικρό κόστος
300-400 $/ευρώ ή ώρα ???
Καλά αν είχαμε τέτοιες υποδομές σε αυτές τις τιμές στην Ελλάδα, σίγουρα θα είχαμε μετρήσει εξοπλισμό και εξοπλισμό, για χόμπι ή και για δουλειά, τεκμηρίωση κ.ο.κ.
Θα ήθελα άρα να σας ρωτήσω εάν γνωρίζετε ποια πανεπιστήμια/φορείς/εταιρίες έχουν αντίστοιχο θάλαμο , και κατά πόσο είναι ενοικιαζόμενοι και σε τι τιμή?
Προς ενοικιαση
This room is available for hire. The charge is £65 per hour for commercial companies and £45 per hour for academic institutions.
Technical assistance can also be provided at £50 per hour.
http://www.ucl.ac.uk/psychlangsci/research-facilities/anechoic-chamber
Επισης (αν και μικρου μεγεθους)
http://www.ets-lindgren.com/AnechoicChamber
Γενικα, ολοι μα ολοι αυτοι οι χωροι ειναι προς ενοικιαση. Ακομα και αυτοι που ανηκουν σε ανταγωνιστριες εταιριες γιατι δεν ειναι ευκολο να γινει οικονομικη αποσβεση της επενδυσης.
Το κοστος ενοικιασεις εξαρταται απο την συχνοτητα "λειτουργιας" στο χαμηλο. Οσο πιο κατω παει το δωματιο τοσο πιο ακριβο ειναι στην ενοικιαση γιατι αντιστοιχα τοσο ακριβο ειναι στην κατασκευη (το κοστος κατασκευης αυξανει γεωμετρικα με τον ογκο σε λιτρα του χωρου)
Ελαχιστες κατασκευαστριες εχουν δικο τους, η Bryston που προσφατα παρουσιασε σειρα ηχειων χρησιμοποιησε το δωματιο του Εθνικου κεντρου ερευνων του Καναδα
50 ευρώ την ώρα … οριακά .. ούτε στούντιο δε βρίσκεις να νοικιάσεις στην Ελλάδα …
Πως τα έχουμε καταφέρει και δεν έχουμε τέτοιες βασικές υποδομές ?
Η ΕΛΒΟ .. που πάει και αυτή για κλείσιμο έχει ένα θάλαμο αλλά για ραδιοκύματα
Το ΕΜΠ νομίζω κάποτε κάτι είχε ?!
Εχει... αλλα δεν γνωριζω το καθεστος, κατασταση και προσβαση
Ανηχοϊκό θάλαμο διαστάσεων 3,5x6,5x3,3m[SUP]3[/SUP]
