mission cyrus 2 + psx
Status
Not open for further replies.
dstd123
5 October 2010
7
Πωλείται ολοκληρωμένος ενισχυτής μαύρος με το
έχτρα τροφοδοτικό του κε με Phono stage mm/mc
mission cyrus 2 + psx Σε Αρίστη λειτουργική
κατάσταση 300Ε
PHOTO:http://img534.imageshack.us/i/dsc00176hp.jpg/
Continuous power - 50W/CH (both driven into 8 Ohms) 80W/CH (both driven into 4 Ohms)
Continuous power (with PSX connected) - 70W/CH (both driven into 8 Ohms) 125W/CH (both driven into 4 Ohms)
Distortion - (1kHz) 0.003%, 1kHz (into 8 Ohms) 0.004%, 1kHz (into 4 Ohms)
Frequency response (line input) - -3 dB, 1Hz and 50kHz
Frequency response (phono RIAA) - 20Hz – 20kHz ± 0.2dB
Damping factor - 100
Slew rate - 10
Sensitivity (reference 1W output) - MM: 0.3mV, MC: 0.02mV, Line: 50mV
Input impedance - 14k (RCA), 47k (MM), 100k (MC)
Maximum output voltage - 11V (Tape out)
S/N Ratio (reference 1W output) - MM: 84dBA MC: 75dBA Line: 86dBA
Dimensions - (H x W x D) 85mm x 215mm x 345mm
Weight - 4 - 5kg (depending on version)
Finish - Black or grey
Cyrus PSX - Power Supply
Specifications
Output voltage - ± 40V
Output impedance - 1 Ohm
Ripple - 750mV peak to peak at 140 watts into 8 Ohms
Noise - 300uV
Transformer regulation - 3% at 500VA
Total PS capability - Typically 0.1 Farad
Finish - Black or Grey
Status
