Modbook : το iPad οπως θα επρεπε να ειναι ...
spyrmak
19 February 2007
4,747
Aθηνα
http://www.axiotron.com/index.php?id=modbookpro
Introducing the new standard for excellence in tablet computing.
The Modbook® Pro is the ultimate tablet computer. Constructed from a unibody Apple® MacBook® Pro base system, Axiotron’s Modbook Pro combines blazing speed and power with new cutting-edge hardware and software features. From its sleek aluminum enclosure to its innovative tablet tools, the Modbook Pro reimagines the tablet computing experience.
Style. Strength. Substance.
The Modbook Pro* features a multibody abstraction design made from precision machined aluminum. There are no exterior sheet metal or plastic parts, providing unprecedented structural strength.
To build Axiotron’s Modbook Pro, the components of the Apple MacBook Pro base system are attached so as not to interfere with the normal functioning of its hardware and software, including the Mac OS® X Snow Leopard® operating system.
Elegant black luster finish. Sturdy aluminum construction. Innovative engineering to retain the functionality of its base system. The Modbook Pro has it all.
Stay connected.
The Modbook Pro includes Ethernet, FireWire® 800, USB 2.0 (x2), Mini DisplayPort, digital audio, SD card slot and Bluetooth — plus a three-button keybar for on/off, Mod Key and battery indicator. On the top of the Modbook Pro is the optical drive bay and pen garage with magnetic pen catch.
Pen with touch. The best of both worlds.
The Modbook Pro employs revolutionary new SynergyTouch™ technology developed by Axiotron. SynergyTouch adds touch in support of pen-based input. Unlike any other touchscreen computer, the Modbook Pro’s Synergy technology enables pen and touch input simultaneously.
On the Modbook Pro’s flush-bezel mounted ForceGlass™ screen, you can draw or write using the digitizer pen and type text or keyboard shortcut commands — at the exact same time! Use your finger to zoom in and out with the on-screen software slider pad. Or pan and scan active content by moving your finger on the virtual touchpad.
The SynergyTouch user interface appears on the screen as translucent overlays of buttons, pads and alphanumeric keys, providing literally unlimited options for system control and data input while using the digitizer pen.
Feature-rich, fast and fun.
With a 2.53GHz Intel® Core™ 2 Duo processor in the base system, your Modbook Pro becomes the fastest tablet on the planet. And the WXGA display offers a crystal-clear visual presentation. At 0.93 inches, Axiotron’s Modbook Pro is thinner than its Apple MacBook base system. Graphics? Enjoy NVIDIA® GeForce® 9400M graphics processing.
Highly accurate Axiotron Quickscript™ handwriting recognition technology powers your writing and notetaking. And the Modbook Pro fully supports landscape and portrait mode.
As an option, your Modbook Pro comes with a partitioned drive pre-installed with Microsoft® Windows® 7, giving you the world’s best tablet PC. Or stay on the Mac® side of the drive — the world’s best Mac tablet computer!
The Modbook Pro. Tablet computing, reimagined.
ειναι πραγματικο προιον ? ( ! )
"The Axiotron Modbook Pro is an aftermarket modification of the MacBook Pro manufactured by Apple Inc. This modification of your MacBook Pro will void your existing Apple warranty. After modification, Apple or its authorized service providers will be under no obligation to repair your computer. Your Axiotron warranty will replace the previous warranty. Only Axiotron Authorized Service Providers are authorized to service and repair your Modbook Pro."
Σύμφωνα με τα παραπάνω ναι είναι πραγματικό... κάποιος modiφάκιας το φτιάχνει... Φαίνεται φοβερό, αλλά η τιμή του είναι για γέλια... (3000$ μαζί με ένα macbook pro που θα του πας).
