Nabilosat DM800 Pure Flash 10DEC08, with Barry Allen 4.6.38
What is the Nabilosat DM800 Pure Flash ?
This image is a simple, pure CVS image to install to flash memory. It is reccomended to those who like the multiboot option with Barry Allen. It is light, fast, reliable and, most of all, upated. Therefore, it is the best solution for multiboot purposes.
What is included in this image ? This image is including the latest available edition of Barry Allen: 4.6.38
Why should I install this image in flash ? Because it includes all the latest drivers and kernel modules required to install new images in multiboot. Nabilosat team is about to release version 0.5 of its Black Hole image. If installed to multiboot, the new Black Hole v0.5 requires an updated image in the flash memory. For this reason, Nabilosat team prepared this Pure version for you.
How do I install Barry Allen with this image ? Barry Allen will be automatically installed at the end of the default wizard
Will I loose the images alread installed on my media ? No, you will not loose any of your favourite images, already installed to your media. You will reboot and find them again, ready to be used.
How do I install it to flash ? You can install it via WebInterface or via serial. However, it is important that you read the simple instructions reported here under.
Release Details Nabilosat Bootlogo by MaximoII
Barry Allen 4.6.38 included
TARGET_ARCH = "mipsel"
TARGET_OS = "linux"
MACHINE = "dm800"
DISTRO = "opendreambox"
DISTRO_VERSION = "1.5.0"
TARGET_FPU = "soft"
COMPILED DATE = "10 december 2008"
ENIGMA2_CVS_DATE = "10 december 2008"
ENIGMA2_VERSION = "2.6 experimental"
BARRY_ALLEN_VERSION = "4.6.38"
Instructions
1) Flash your DM 800 with Web Interface or DreamUp and serial cable
2) Complete the Default Wizard to setup the basic steps
3) Upon Wizard completion, you will be prompted to press OK to install Barry Allen
4) Press OK once, and wait for the Wizard to install Barry Allen
5) When Barry Allen is updated, the Default Wizard will be completed.
6) Reboot your Dreambox
Barry Allen will have been updated. You will find your previous images listed, choose your favorite as always.
