Nad blu player
argi
Banned
17 July 2006
7,032
salmonela
Ωρα και για την ναυαρχιδα της nad , αν και θυμιζει αλλες εποχες ειναι σχεδιασμενο απο το 0 .Πλην της εμφανισης βεβαια.
With a look different than most BD players on the market, NAD’s newest player – dubbed the Master Series M56 Blu-ray Player – is encased in a steel chassis and die-cast aluminum front panels. The noise isolating design is supported by a quartet of aluminum feet with silicon rubber inserts.
NAD’s M56 is BD Live capable, and features a 1080p resolution delivered at 24 frames per second. Audio is delivered through a 7.1 Linear PCM at 24-bit resolution. Lossless compression formats are supported by the M56, as well as legacy formats from Dolby Digital and DTS. In addition to HDMI output, the M56 also features a 7.1 analog output, enabling users to get a truer home theater experience.
NAD takes great care to mention that the M56 has a fast loading time for Blu-ray content – typically only a few seconds – a feature much celebrated in Oppo’s BDP-83 player. The M56 also features an Instant Open feature for quickly ejecting discs. The Master Series M56 Blu-ray Player from NAD is available now at authorized dealers
Sorry παιδιά αλλά εμένα δεν μου αρέσει (εμφανισιακά συζητάμε πάντα). Βέβαια αν είναι καταπληκτικό για τα λεφτά του, τότε αλλάζει το πράγμα.
Σαν Philips VHS της περασμένης δεκαετίας είναι... :flipout: :flipout: :flipout:
Από μηχανισμό ανάγνωσης και κυκλώματα έχουμε καμμιά πληροφορία;
