Nagra HD Dac
Gojakla
20 May 2009
5,856
Official Site
High-Definition Digital to Analog Converter
The HD DAC is the purist interface from the digital world to pure audio excellence. The no-compromise definition reproduces the original sound with total integrity.
Its state-of-the-art design concept, linked with high resolution DSD features are married with the Swiss know-how from the professional domain.
Features
Conversion
The HD DAC is designed to convert a digital signal to analog with total integrity, without introducing the slightest impurity or coloration to the original sound.
This objective has been achieved with perfection, and sound has never reached such a true level of definition.
The effort put into the design and exactitude of the Nagra HD DAC was exceptional from every perspective.
Its circuits, that adopt the DSD 2X (Direct Stream Digital 128), were developed in association with Andreas Koch, the pioneering engineer of the DSD format.
They run at the highest resolution available today, 128 times that of a standard CD and twice that of SACD.
Analog section
The analog section is also the object of a superlative approach.
Thanks to the quality of the signals supplied from the digital conversion circuits, the traditional steep slope filters have been totally eliminated.
The consequence of this is the preservation of transients and harmonics, thus the music presents an exceptionally natural sound.
Some of the critical design elements include Ultra high performance drivers, hand-wound transformers, and a tube driven output stage.
Power supplies
There are 25 precision ultra-low-noise internal power supplies that drive the unit, giving each element its own independent and pure supply source.
The Nagra HD DAC converter uses TWO stand-alone external power supplies, one for the digital section and the other for the analog,
keeping the two parts independently isolated. It can be paired up with the Nagra MPS multiple supply unit allowing it to reach its ultimate performance.
Connectivity
The HD DAC is equipped with extensive connection possibilities, allowing integration in all types of domestic and professional systems.
It is particularly suited to computer environments thanks to its audio USB input, through which it receives signals up to the DSD 128 format from a PC or MAC.
6 Moons Review
Audiostream Review
HiFi+ Review
PRICE
$22,130​
Δεν ξέρω πως θα παίζει, αλλά από εμφάνιση τα Nagra είναι έρωτας με την πρώτη ματιά!
Αυτό έπαιζε στην έκθεση κάτω στην Afrodites Vision? καλό ρε γμτ αλλά ακριβό...
ΥΓ. Ψιτ Αντωνάκι... ψάχνεις για ντακάκι ατιμούλικο?... αυτό πάντως είναι όντως ευκαιρία... -bye-
Αν είναι, να ξέρεις ότι θέλω και εγώ, να μας κάνουνε καλύτερη τιμή... :flipout:
Πάμε για Powebuy;
Είμαι περίεργος... :chinscratch:
Αν μαζευόμασταν χίλιοι (1000!), :idea:
Πόσο θα μπορούσαμε να κατεβάσουμε την τιμή; :Banane0:
αυτοί οι άνθρωποι ξοδεύουν το 1/3 του r&d τους στα πόμολα και στα χερούλια.
Γι αυτά και μόνο θα τα χαλάλιζα τα φράγκα....
Αντιθέτως, χρησιμοποιούν τα ίδια κουμπιά από τη δεκαετία του '60, που είναι σαν να περίσεψαν από το κέντρο ελέγχου του Σπούτνικ.
Θα έκαναν καμιά μεγαλη παραγγελία στη Σοβιετική Ένωση τότε φαίνεται και τους έμεινε στοκ.
αμα προσέξεις καλά, θα δεις ότι τα εξέλιξαν.
Λίγο είπαμε.
το 1/3
Εγώ αγαπάω διακόπτες Nagra πάντως.
Είναι ίσως το μοναδικό μη-minimal που μου αρέσει τόσο.
(Κι εγώ στο PB αν είναι να βοηθήσω! )
Παιδια ευχαριστω για το ενδιαφερον αλλα αν ειναι να το κανουμε mainstream το μηχανακι, χεστο.
Θα παω για αλλο... :flipout: :flipout: :flipout:
Απάντηση: Re: Nagra HD Dac
(έλα κοντά εσύ,θα βρω ένα ακόμα μπλοκ αλουμινίου να σκάψουμε και θα φτιάξουμε δύο.Θα φτιάξεις και τις καλλιτεχνίες απ' έξω και ποιος μας πιάνει :flipout: )
