νεα προδιαγραφη hdmi
argi
Banned
17 July 2006
7,032
salmonela
με αμφιδρομη μεταφορα ηχου και οχι μονο
πληροφοριες στο hi tech που βγηκε σημερα
Σίγουρα το Hitech θα ξέρει πράγματα που δεν μπορεί κανείς να βρει στο διαδίκτυο....
Προφανώς είναι απαραίτητες οι νέες προδιαγραφές για να βγάλουν obsolete τις προηγούμενες και να πουλήσουν ακόμα μια φορά "νέα" τεχνολογία...
http://www.hdtvmagazine.com/news/20...speeds_and_address_emerging_auto_industry.php
Next-Generation HDMI Capabilities Will Add Networking, Higher Speeds and Address Emerging Auto Industry
LAS VEGAS, January 7, 2009 - HDMI Licensing, LLC, the agent responsible for licensing the High-Definition Multimedia Interface™ (HDMI™) specification, today announced an overview of the capabilities and features of the next version of the HDMI specification which will be launched in the first half of 2009.
"HDMI has reached an installed base of more than 600 million devices and now touches almost every consumer device that plays HD content. We want to give the industry a preview of where the HDMI specification is headed as we continue to innovate and meet the needs of this dynamic marketplace," said Steve Venuti, president of HDMI Licensing, LLC.
Our goal is to address 5 key industry trends in the coming spec:
* - Networking - Consolidation of HD video, HD audio and now high speed data with the addition of Ethernet in the HDMI cable.
* Audio Return Channel - Elimination of a S/PDIF cable by allowing a TV to send audio streams upstream to an A/V receiver for processing and playback over the HDMI cable
* Performance - 4kx2k and 3D are high performance features to be met by increasing the upper limit of the HDMI link
* HD in your Car - New connector specification for the auto industry as worlds' largest auto makers move to digital HD video and audio for 21st century cars with HDMI
* Smaller connector - New smaller 19-pin connector
Κάποτε οι εταιρείες, ετοίμαζαν πρώτα τα προϊόντα τους και μετά τα διέθεταν στην αγορά. Πλέον, δυστυχώς, έχουν τα ηνία οι οικονομικοί μάνατζερ 3ετών ή 5ετών συμβολαίων που το μόνο που τους νοιάζει είναι το πως θα γεμίσουν την τσέπη τους. Αντι να κυκλοφορήσουν το Blu-Ray κατά το 2011-2012 στην έκδοση των 100-150 γίγα, με μικρότερη συμπίεση, χρώμα 4:2:2, τις παιδικές ασθένειες λυμένες και το τελικό HDMI έτοιμο, αυτοί βάλθηκαν να καταστρέψουν την αγορά του home video...
Απάντηση: Re: νεα προδιαγραφη hdmi
:a0210::a0210::a0210:
μου φαινεται ολα τελος optical,spdif,usb ethernet dsub
ολα με hdmi θα τα συνδεουμε σε λιγα χρονια
αμφιδρομη μεταφορα ηχου+
νεα βυσματα
καιρος ηταν
5 χρονια βαρεθηκαμε με τα ιδια
Re: Απάντηση: νεα προδιαγραφη hdmi
Μπα.. το HDMI ήταν είναι και θα είναι αμιγώς consumerάδικο standard.
Δεν το βλέπω να υποστηρίζει USB 3.0 και 10 Gigabit ethernet σύντομα.. και εμείς για αυτά θα ψάχνουμε σε έναν χρόνο (καλά, το 10Gigabit ίσως είναι λίγο τραβηγμένο.. :p ).
νεα βυσματα
καιρος ηταν
Καπου το πας παλι εσυ αλλα δεν ειμαι σιγουρος....
Βρε μπας και ψαχνεις δικαιολογια μπας και αλλαξεις επιτελους κανα καλωδιο;
:p
Το USB 3 πλεον ειναι μια πραγματικη αναγκη (οχι απως τα pci-ex 1-2-3 κλπ sata 1-2-3 κλπ).
Επισης ενα προτυπo ethernet το οποιο να υποστηριζει καλες ταχυτητες (100 mb/s +) με καλωδια τυπου cat 5/6 ειναι το λιγοτερο καλοδεχουμενο.
Μα το SATA είναι είδη πρόβλημα αν υπολογίσεις ότι σύντομα (πολύ) θα κυκλοφορούν SSDs με internal RAID 0 controller και διαμεταγωγές 200, 300+ ΜΒ/sec.
Επίσης οι high end RAID Controlers που μπορείς να παίξεις με 4-8 SSDs σε RAID 0 (όπως oi ARECA με τιμές γειά σου 1000+) δουλεύουν σε PCI-Express x8 και σύντομα Χ16.
Τίποτα δεν πάει χαμένο απλά δεν είναι πάντα χρήσιμο για το ευρύ κοινό.
Για το HDMI τώρα όσον αφορά την αμφίδρομη επικοινωνία ήχου από την TV προς Receiver Pre/Pro μάλλον άχρηστο Ελλάδα εκτός κι αν έχεις SKY HD. To ethernet και τα υπόλοιπα (4k, 2K) χρήσιμα αλλά δεν χάλασε κι ο κόσμος ακόμα χωρίς αυτά μιας και για να δεις 4Κ πρέπει να έχεις τουλάχιστον μπάρμπα στο Holywood να σου δίνει υλικό. Να μην πω για το κόστος του προβολέα (ακόμα).
Απάντηση: Re: Απάντηση: νεα προδιαγραφη hdmi
αφου ξερεις .............
το αλλαξα γιατι ειχε προβλημα
ευτυχως καλυφτηκε απο εγγυηση
-bye-
Να ρωτήσω... Θα πρέπει να αλλάξουμε AV's για τα καινούρια ή με έναν αντάπτορα θα γίνεται η δουλειά?
Επειδή αλλάζει και το βύσμα σε μικρότερο 19-pin...
Με τον αντάπτορα λογικά δεν θα έχουμε τα καινούρια προνόμια των νέων καλωδίων εε?
Είμαι προ της αγοράς νέου ενισχυτή....... :/
Για να έχεις όλη τη λειτουργικότητα του καινούργιου πρότυπου (όποια είναι αυτή, όταν βγει) σίγουρα θα χρειαστεί να αλλάξεις και τον ενισχυτή σου, όπως φυσικά και την πηγή σου.
Αν όλη η φασαρία γινόταν μόνο και μόνο για να αλλάξουν το βύσμα, ζήτω που καήκαμε.
