Νέο Gemini v3.40
AlexT_
10,461
Κυκλοφόρησε σήμερα η νέα έκδοση v3.40 για δέκτες Dreambox 7020, 7000, 56X0 και 500.
Το Gemini Team υποστηρίζει αδιάκοπα τους δέκτες Dreambox και έχει αποκτήσει φανατικούς φίλους.
Τα χαρακτηριστικά:
Gemini v3.40:
Technical Infos:
* Enigma of: 29.01.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6-Expert
* Busybox 1.2.2
* Tuxtxt V1.99
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* YELLOW - Quick-Button (can be configured via BP)
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN - subservices
Features:
* Own addon server via internet.
* AutoCam: Emu can be linked to channels/provider
* Cam settings: For example emu renaming, multichannel patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Download and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma settings)
* Gemini news loaded in background
* JPEGs can be rotated and the EXIF tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Random function for MP3 and OGG
* Quick-Button-Menu: Many extra features for the yellow button
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB
(>=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working without internal hard drive, mountpoint set to "var/mnt/hdd" and at
least 3GB disk space)
* Extra menu: Settings for many features like Inadyn, HTTPD, EPG-Cache, "/var" swap-out and many more
* Backup function
* Dreamnetcast: inclusive Shoutcast TOP(100)
* Background pictures for Radio, MP3 and SCAN can be changed via Blue Panel
* Own scripts can be started via Blue Panel
* Calender including reminder (can be changed via .../calendar.conf)
* MVI's can be converted and tested (from JPG, BMP, GIF or PNG)
* Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabic language
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be created in the filemenu
(BP->Extras/Settings->Root-Entry)
* Create your own Satellites.xml
* Dreambox can be used as printserver
(BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Alarm clock with volume offset adjustable playing your own WAV-files.
* Display of current channel stream rates (>=7000)
* Multisocket second camd socket (cam1.socket)
switchable.
* Register an own addon server (useraddon.xml)
* Provider, Frequency, symbol rate and FEC displayed on infobar dependent on skin)
* Picon already integrated in Gemini
* "real" automount, Examples in the /var/etc/automount.conf. Devices, NFS or Cifs will be mounted automatically (Editor in
BP-Menu)
* dropbear active in all Images (SSH - Daemon)
* cifs-1.44
* extensions for Skins (Preview Screenshots, 3D-Text, pictures can be used as Progressbar)
New:
* Background Pictures (radio- and file- mode) can be used as Screensaver. They have to be in the same format which is used in the Screensaverplugin from @bexbier
* Background picture can be deactivated (plasma fix)
* Dreamnetcast and Streamripper (direct recording from server and coding into mp3´s)
* Upnp client and server (DM500 to DM7000 must be installed as addon), link
* Position of the Infobar can now be changed without editing the skin files
* Dropbear (ssh) can now be tourned on/off (DMM500 to DM7000 standard is OFF)
Fix + Update:
* Remote-Control in the WebIf
* see CVS
Interfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present if several processes running in background.
