Καλημερα σας.
Χθες το βραδυ πηρα το παρακατω promotional e-mail απο τους κινεζους που βγαζουν αυτα τα μικρα ενισχυτακια σχετικα με το νεο τους μοντελακι, το οποιο και παραθετω προς πληροφορηση σας.
Επιπλεον ειναι ενδιαφερον οτι τωρα εχουν κι ενα full range ηχειο στη γκαμα τους.
Dears Customers,
Thanks for your supports on MiniWatt!
We're glad to inform you that our N3 (12AX7+EL84 Integrated Tube Amp, Silver and Black colors) is now available for sale in our online shopwww.miniwatt.com.hk.
N3 outperforms the previous model - MiniWatt S1 quite a lot, and the size 130mm (w) x 130mm (d) x 130mm (h) is only slightly bigger than S1, but the output power is 3.5W per channel. If you like MiniWatt S1, you will LOVE N3. Here are the specification and photos.
Beside, we have launched a fullrange monitor speaker - N2, and it matches well with N3. Nice combo to enjoy music!
Our website is revamped, and you can get the most updated info in twitter and facebook, pls follow us or post your comments on the facebook's wall.
Tubes
• Driver - TungSol 12AX7
• Power - Sovtek EL84 (Matched Pair)
Specifications
• Power Output: 3.5W+3.5W @ 8 ohms
• Frequency Response: 30-40Khz (+-1db)
• Input Sensitivity: 500mV
• Signal-to-Noise Ratio: -80dB / 3.5W
• Residual Noise < 1mVac
• Input AC Voltage: 100-250Vac
• Power Consumption: 38W
• Input Impedance: 50K ohms
• Output Impedance: 8/6/4 ohms (Japan Z11-EI48*24 Output Transformers)
• Dimensions: 130mm (w) x 130mm (d) x 130mm (h)
• Weight: 2.6kg
• Input: RCA Jacks
• Output: Banana Jacks
• AC: Standard IEC Jack with Fuse protection (2A Fuse)
Price:
US$378 + Flat shipping rate to all around the world US$50
Once again, if you have any questions on our products, just let us know and we will try our best to answer. Thanks!
Sales - miniwatt
www.miniwatt.com.hk
Email: [email protected]
Dears Customers,
Tubes
Specifications
• Weight: 2.6kg
• Input: RCA Jacks
Price:
Sales - miniwatt
www.miniwatt.com.hk
