ΝΕΟ USB DAC NORTH STAR DESIGN
16 June 2009
25
Νεο DAC απο την Ιταλικη NORTH STAR DESIGN με εισοδο USB στα 192kHz-32bit.
The unit work with XP, Vista, Win7 32 and 64 bit and with MAC OS Snow Leopard 10.6.
As for its use with conventional sources presents
maximum flexibility in interfacing with four digital
inputs (coaxial, optical, balanced, I2S) capable of
handling signals up to 192kHz-24bit. The unit is
equipped with an anti-jitter and an upsampler that,
regardless of the frequency and resolution of the
input signal, rises it up to 192kHz-32bit. The digital
section is completed by a pair of converters in
balanced mono configuration that can handle digital
streams up to 192kHz-32bit.
But what makes this converter so special and like no
other is the ability to reproduce audio files with
frequencies up to 192kHz and resolution up to 32
bits. It’s equipped with an
USB2.0 high-speed port (i.e. capable of transferring
data at 480Mbit/sec) which overcome the limit of
96/24 common to other converters.
By connecting a PC or a Mac to the USB2.0 port
you will be able to play audio files in high resolution
beyond the limits imposed by the previous
technology on USB ports.
Appropriate drivers have been developed for different
operating systems, thus ensuring a proper timing
and a no-compromise reproduction quality.
But all this would not be enough to get an audiophile
reproduction.
One of the big challenges in the reproduction of
streaming music is the (negative) influence of the
computer on the quality of reproduction. Many
audiophiles have the experience that for playing
music from a PC or Mac via a dedicated sound
cards, also of great quality, one often faces
limitations related to noise generated by power
supplies and not to mention the noisy fans needed to
cool down the computer, which are limiting the
pleasure of listening.
Forget about all that. Today you can get the most
from these sources by designing the converter to
make it independent of the computer used for
playback.
Two are the devices used: data resynchronization
and magnetic separation of the ground.
The first solution allows different methods to release
from the transmission on USB, using on-board
reference oscillator with low jitter of the DAC is
capable of re-clocking of incoming data from the
computer with absolute precision.
The second solution allows to completely decouple
the ground of the computer from that of the DAC,
allowing the transmission of signals at high speed
but without the noise generated by the computer.
We can say that, whatever the computer, the
playback quality will always be at the highest levels.
Whether it's music from a PC, MAC or traditional
source such as a CD player, DAT, satellite receiver 's
USB dac32 represent the heart of your system,
capable of dialoguing with each type of source
always at the highest levels.
Η συσκευη θα ειναι παραδοτεα στα μεσα του Απριλη με
τιμη 1700 Ευρω με το ΦΠΑ.
Περισσοτερες πληροφοριες ακολουθουν συντομα.
Τασος Παπαγεωργιου.
ΑΚΟΥΣΤΙΚΗ ΚΡΗΤΗΣ.
Καλημερα σε ολους και χρονια πολλα.
Εφτασε το νεο USB DAC 32 της Ιταλικης north star design.
ο μετατροπέας πραγματοποιεί τοπικό χρονισμό του σήματος από τον υπολογιστή και είναι γαλβανικά απομονωμένος από αυτόν ώστε να ελαχιστοποιήται ο θόρυβος.
Τεχνικα χαρακτηριστικα:
DIGITAL INPUT FREQUENCY 32Khz-192Khz up to 32 bit.
DYNAMIC RANGE 126 db.
S/N RATIO 112 db.
INPUTS 2x S/PDIF(1RCA coax,1TOSLINK)1xXLR AES/EBU,
1xUSB2.0,1xI2S RJ45.
OUTPUTS BALANCE XLR,UNBALANCE RCA.
2 separate power supplies with separate toroidal transformers.
Τασος Παπαγεωργιου.
ΑΚΟΥΣΤΙΚΗ ΚΡΗΤΗΣ.
