Νεος (?) Infocus IN81
http://www.infocus.com/Products/Projectors/IN81.aspx
Display
Native Aspect Ratio:16x9Supported Aspect Ratio:16:9, 4:3Brightness: (Video Optimized Lumens)Whisper: 1100 max ANSI lumens
High Bright: 1400 max ANSI lumens max ANSI lumensContrast Ratio:10000 : 1 Full On/Full OffDisplay Technology:DarkChip2™ 1080p 12° LVDS, DLP™ by Texas InstrumentsData Compatibility:640 x 480, 800 x 600, 1024 x 768, 1280 x 1024, 1280 x 720, 1920 x 1080Video Compatibility:Full NTSC, PAL, SECAM, 480i, 480p, 576i, 576p, 720p, 1035i, 1080i, 1080p/24, 1080p/30, 1080p/50, 1080p/60Color Wheel (DLP Only):7-segment, D65K (6500K) color calibratedNative Resolution:1920x1080Projector Placement:Ceiling Projection, Front Projection, Rear ProjectionSMPTE Brightness:Up to 14.25' (4.3m) diagonal with 1.0 gain screenLamp Wattage:Whisper: 250 Watts
High Bright: 300 WattsLamp Life:Whisper: 2500 Hours
High Bright: 2000 HoursMinimum Image Size:3.06 ft (0.93 m)Maximum Image Size:16.92 ft (5.16 m)Standard Lens Zoom:1.2 : 1Standard Lens Throw Ratio:1.85-2.22:1 (Distance/Width)Standard Lens Image Offset Ratio:136%Standard Lens Projection Distance:4.92 - 32.8 ft (1.5 - 10 m)Digital Keystone Correction (Vertical):+/- 13°Digital Keystone Correction (Horizontal):Not AvailableLens Shift:Not AvailableInputs and Outputs
DVI:Number of Inputs: 1
Requires M1 to DVI cable (SP-DVI-D)M1:Number of Inputs: 1
Accepts VGA, DVI, HDMI, & Component Video through optional M1-DA adapters.HDMI:Number of Inputs: 1
HDCP SupportedBNC:Not AvailableComponent (RCA):Number of Inputs: 1VESA (HD15):Number of Inputs: 1
Requires M1 to VGA cable (SP-DVI-A)S-Video:Number of Inputs: 1
4-pin mini-DINComposite (RCA):Number of Inputs: 1Standard Definition TV:Composite RCA, S-Video, Component RCAEnhanced Definition TV:Component RCA, HDMI, M1-DAHigh Definition TV:Component RCA, M1-DA, HDMIComputer:M1-DAHDCP Support:YesStereo RCA Jacks Inputs:NoStereo 3.5 mm Mini-jack Inputs:No12v trigger for motorized screens (3.5 mm mini-jack):YesProjector Control:RS-232, Remote, 3.5mm Wired RemoteSpeakers:Not AvailableMonitor Output:NoAudio Output:Not AvailableCompatibility
Data Compatibility:640 x 480, 800 x 600, 1024 x 768, 1280 x 1024, 1280 x 720, 1920 x 1080H-Sync Range:Not AvailableV-Sync Range:50 - 85HzVideo Compatibility:Full NTSC, PAL, SECAM, 480i, 480p, 576i, 576p, 720p, 1035i, 1080i, 1080p/24, 1080p/30, 1080p/50, 1080p/60General
Audible Noise:30 dBActual Dimensions:Height: 5.83 in (14.81 cm)
Length: 17 in (43.18 cm)
Width: 18.75 in (47.63 cm)
Actual Weight:14.1 lbs (6.4 kg)Shipping Dimensions:Height: 10.5 in (26.67 cm)
Length: 23.4 in (59.44 cm)
Width: 21.6 in (54.86 cm)
Shipping Weight:21.2 lbs (9.62 kg)Projector Warranty:2 yearsLamp Warranty:6 monthsAccessories Warranty:90 daysOperating temperature:
(at sea level)50 - 95° F (10 - 35° C)Maximum Altitude Supported:7500 ft (2286 m)Typical Power Consumption:350 WattsMaximum Power Consumption:375 WattsPower Supply:100 - 240 Volts at 50 - 60 HzMenu Languages:English, French, German, Italian, Japanese, Korean, Norwegian, Portuguese, Russian, Simplified Chinese, Spanish, Traditional ChineseApprovals:UL, c-UL, TUV GS, GOST, C-Tick, NOM, IRAM, FCC Class B, ICES-003 Class B, CISPR22/EN55022, EN55024/CISPR24, CB certified in accordance with IEC60950-1/EN60950-2, MIC, CE, VCCI, WEEE
