Νεος Marantz SR4002!
BENZINA
11 June 2007
528
Thessaloniki
With features such as seven channels of all discrete amplifier stages, HDMI V1.3 Switching with V1.1 Repeating, (7.1) LPCM via HDMI, and a ridiculously low MSRP of only 549.99, The Marantz SR4002 surround receiver just might be the best buy of the year.
From the legendary company of Marantz comes an entry-level home theater receiver that raises the bar in performance and features that will no doubt have many wondering how are they making a profit. From their humble beginnings in the 1950’s and their rise to audio prominence in the 1970’s, Marantz has always been a force to reckon with. Although they fell off the audio map for a while in the late 80’s and early 90’s, the last fifteen years or so has seen Marantz come back with a vengeance. This latest crop of receivers from Marantz is sure to raise the eyebrows of audio enthusiast, and cause heartburn to some other audio companies.
In keeping true to their audiophile heritage, the receivers amplifier section is rated at 80-watts x 7 with all discrete amplifier stages. Also, The SR4002 receiver comes fully loaded with features previously found on units that were considerably more expensive. These features include 192kHz/24-bit processing on all seven channels, full complement of DTS processing including DTS 96/24, Dolby Digital EX and Pro-logic IIx, Dolby headphone, HDCD decoding (unheard of in this price range), HDMI V1.3 switching and V1.1 repeating, S-video up conversion to component, 8-channel input and 8-channel pre amplifier outs, (this will have some separates people thinking), and M.R.A.C. auto calibration. The receiver also supports 7-channels of LPCM over HDMI for compatibility with HD DVD and Blu-Ray disc players. We think this is one heck of a feature set for a receiver in this price range.
The Marantz SR4002 is no slouch when it comes to inputs either. Most receivers in this price class are usually input challenged, but not the Marantz. Having no less than three HDMI inputs, three component inputs, five S-video, five composite video, two each of both optical and coaxial digital inputs as well as front panel inputs, this receiver can handle it all. As always, fit and finish appear to be excellent on this receiver and we would expect nothing less from Marantz. We just think it is an extra special bonus to have this all carry down to an entry-level receiver.
When features and quality are a must, but the budget is a little tight, the Marantz SR4002 comes to the rescue with an impressive set of features and an even more impressive price that will leave even the most finicky of spouses smiling, and your neighbors drooling. Just don’t tell them how little you spent.
http://www.audioholics.com
Εδω πότε και πόσο αραγε?
Μην τρέχετε άδικα στο www.pixmania όταν το δικό μας Perfectshop τον έχει 469 ευρώ και με 4 χρόνια εγγύηση της επίσημης Ελληνικής αντιπροσωπείας !!!!
Ριξτε μιά ματιά σε αυτά τα μαγαζιά (ολα γύρω στα 470 ευρώ) :
http://www.perfectshop.gr/pub/el/catalog/ProductDetail.aspx?13682
http://www.ihoekfrasi.gr/productsDetails.asp?catID=10&prID=144
http://www.atsidas.gr/Product.aspx?ID=1436&MenuID=27
Απάντηση: Re: Νεος Marantz SR4002!
Oλα καλά αλλά μήπως τα 7Χ80 είναι λίγα ?
Η τιμή πάντως είναι πολύ καλή...
Υπαρχει κι ο 5002,με 7Χ90 και εχει και συνδεση με υπολογιστη(rs232 οχι usb) κι ειναι 1kg παραπανω.Τιμη γυρω στα 600 ευρω
Στα 550 ευρώ τον έκλεισα (είχα γνωστό σε κατάστημα με ηλεκτρικά) και τον περιμένω τέλος της εβδομάδας. Μόλις τον παραλάβω θα γράψω εντυπώσεις. Θα παίξει με σετ ηχείων της crystal audio plasma system -bye-
Καλορίζικος και καλοάκουστος.
Τον συγκεκριμένο δεν τον έχω ακούσει κάπου και είμαι περίεργος γιά τις πρώτες εντυπώσεις σου......έχω καλή διαίσθηση πάντως, γιατί τα πράγματα δεν κρύνονται πάντα με την δύναμη.
Ευχαριστώ αν και βέβαια δεν έχω και μεγάλες απαιτήσεις λόγω του ότι μένω σε πολυκατοικία και δεν μπορώ να ανεβάζω πολύ τα db πιστεύω ότι για τα συγκεκριμένα ηχεία είναι ότι πρέπει για να μην πω οτι και ο 4002 θα μου έκανε αλλά αφού πέτυχα και καλή τιμούλα (πιστεύω) ας είναι. Βέβαια για τα ηχεία απ' ότι έχω διαβάσει δεν λένε και τα καλύτερα λόγια αλλά τα άκουσα και με κάλυψαν οπότε....
καλές ακροάσεις ....
Ευχαριστώ.
Και επανέρχομαι σήμερα παρέλαβα τον SR-5002 :drummer: και μπορώ να πω ότι ο ήχος του με εξέπληξε ευχάριστα. Αρκετά ευκολονόητος στις ρυθμίσεις του (σε σχέση με yamaha 461) και πολύ πιο γλυκός ήχος ειδικά στα audio cd. Το Σ/Κ θα κάτσω να παίξω λίγο με τις ρυθμίσεις να δω και κανένα εργάκι και επανέρχομαι για πληρέστερες εντυπώσεις. -bye-
καλά να περάσεις μαζί του φίλε μου...κάτσε και ψαξτο για τον ήχο γιατί αυτά τα μηχανήματα έχουν πολλά που μπορείς να πειραματιστεις για να πετύχεις καλύτερο αποτέλεσμα
Γενικα για τους Marantz υπαρχει καποιο θεμα με την αξιοπιστια και την αντοχη τους?Οι περισσοτεροι λενε οτι ειναι αρκετα "μουσικοι" και οχι τοσο "κινηματογραφικοι".Ισχυει?
Σε σχεση με Υamaha και Pioneer,π.χ,ειναι πιο υπερτιμημενοι?
