New Kathrein UFS 922 Twin HD receiver
george664
11 May 2007
1,449
ΡΕΘΥΜΝΟ
New Kathrein UFS 922 Twin HD receiver Written by Administrator Friday, 01 August 2008
Kathrein will release a new [COLOR=blue! important][FONT=Arial, Helvetica, sans-serif][COLOR=blue! important][FONT=Arial, Helvetica, sans-serif]HDTV[/FONT][/FONT][/COLOR][/COLOR] capable Satellite Receiver, also running on Linux. The Kathrein UFS 922 will be the 1st twin HD satellite receiver from this company.
Quite remarkable is the fact that this receiver does support Diseqc 1.1-1.2! The UFS 910 does lack this eagerly awaited option for more then a year now & it seems the upcoming 1.06 firmware still doesn't support Diseqc properly. Some UFS 910 enthusiasts couldn't wait anymore for this highly nescessary option, so some people developped extended Diseqc support themselves. This isn't an ideal situation though...
Enough said about failing UFS 910 firmware support, lets have a look at the new flagship from Kathrein.
The UFS 922 will feature a twin DVB-S2 tuner & a 500 GB HDD. Also this box should play multimedia files, straightwaway from the HDD. The [COLOR=blue! important][FONT=Arial, Helvetica, sans-serif][COLOR=blue! important][FONT=Arial, Helvetica, sans-serif]remote [/FONT][COLOR=blue! important][FONT=Arial, Helvetica, sans-serif]control[/FONT][/COLOR][/FONT][/COLOR][/COLOR] looks more user-friendly then the UFS 910 one, because it features different shaped buttons & the shape of the remote control looks more ergonomic.
Sadly this receiver still lacks an internal cardreader, but still supports 2 common-interfaces to handle CA-modules.
Features
  • Video decoding of MPEG-2 and MPEG-4/H.264 signals
  • Two independent Sat tuners with loop-through output
  • Integrated 500-GByte hard disk to record over 300 hours of standard TV broadcasts as well as approx. 100 hours of HDTV recordings ¹)
  • Recording of radio broadcasts on the integrated 500-GByte hard disk
  • Timeshift function
  • Permanent timeshift (ongoing recording of the selected programme)
  • 16-digit alphanumeric display with status icons to show the channel names and programme information
  • Premium tvtv-EPG (Electronic Programme Guide) for 14 days with detailed information for approximately 60 programmes
  • Extended EPG functions: Sorting according to categories, extensive search function, creation and administration of programme tips
  • Recording list with chapter menu and pictures
  • Multimedia archive for pictures and MP3 playback
  • Common Interface for two CA modules with dual decryption ²)
  • HDMI output enables connection to a flat-screen TV set for optimal viewing comfort
  • Upscaler to upscale Pal signals to 576p, 720p and 1080i as well as automatically
  • Two USB 2.0 ports on the rear panel for connection of external USB storage media
  • One USB 2.0 port on the front panel for software updates via USB stick
  • Ethernet interface
  • Menu-guided first installation
  • Pre-programmed programme list
  • Displays broadcaster logos in various on-screen displays
  • Numerous timer recordings programmable (once, daily, weekly, user-defined and serial timers)
  • 8 favourite channel lists each for TV and radio
  • YPbPr, TV and VCR Scart output
  • Composite colour picture, RGB and Y/C signal output programmable on Scart socket (TV)
  • Optical audio output for Dolby Digital data stream (AC 3)
  • Language selection for programmes broadcast in several languages
  • Suitable for software updates (operational software and channel list separately) via satellite, USB stick and PC
  • On-screen display (OSD) in 9 languages (D, GB, F, I, E, CZ, PL, TR, RUS)
  • DiSEqCTM1.0, 1.1, 1.2 and SCR single-cable control signals
  • LINUX-based operational system
  • Multifunctional tuner on the front panel for easy operation
  • Mains switch
  • 4,000 programme memory positions
  • Delivery scope: Infra-red remote control, batteries, HDMI cable, Scart cable, manual, safety notes, power cable, loop-through cable ¹)
¹) Depending on the data rate of the broadcast being transmitted
²) CA modules and smartcards are not supplied
The Kathrein UFS 922 will be available in silver, or black. No info about pricing & availability yet.
You can discuss here about this new Kathrein receiver in our Forum.
Οντως με ΒΑ το προβλημα λυνεται..
Ομως εκει που μας κανουν πλακα ειναι η υποθεση με το DiseqC.
Δηλαδη τοσο δυσκολο ειναι να βγαλουν το τιμημενο το DiseqC 1,1 - 1,2 για τον UFS-910??? Εδω το βγαλανε απο την αρχη για τον καινουριο τους ο οποιος στην ουσια βασιζεται στον 910. Κ περιμενουμε 1 χρονο τωρα την υποστιρηξη στον 910 και ξαφνικα σκαει ο καινουριος με ετοιμη την υποστιρηξη!!!!
Συγνωμη για το οφ τοπικ, αλλα δεν κρατιεμαι :furious3::furious3::furious3:
Καλησπέρα .
Συμφωνώ απόλυτα .Έγινε κουραστική αυτή η ιστορία ,να περιμένουμε να βάλουν DiseqC 1,1 -1,2 στον ufs-910.
