• 12.1 Megapixels for stunning prints as large as 20 x 30 inches. This is plenty of sharp resolution to capture
the finest details, crop creatively and produce incredible enlargements.
• Amazing 24x Optical Wide-Angle (26-624mm) Zoom-NIKKOR ED Glass Lens - quality optics provide exceptional
images. The lens is built on a proud heritage of producing precision camera optics that deliver superb color
and razor-sharp results. This amazing lens offers unbeatable compositional freedom with its wide-angle (26mm)
to super telephoto coverage (624mm). Sweeping landscapes can be captured as well as zoomed-in close-ups of the
action taking place on the baseball or soccer field!
• Huge, Bright 3.0-inch Vari-Angle High-Resolution LCD and Electronic Viewfinder makes it easy to compose and
share your pictures with family and friends. The vari-angle LCD will tilt and rotate out on a 90-degree angle
enabling you to get those high-angle and low-angle shots. The incorporation of the high-resolution electronic
viewfinder enables you to see through the lens in any type of lighting condition. No more missed opportunities
because the light is too bright to compose your picture!
• New EXPEED image processor ensures high-quality pictures with stunning color and sharpness. Nikon’s comprehensive
digital imaging processing concept incorporates know-how and technologies accumulated throughout our long history of
photographic and digital imaging development. EXPEED is custom-tuned for COOLPIX and applied optimized technologies
render natural-looking pictures of incredible quality and quick response so you will not miss that special moment.
• 4-Way VR Image Stabilization:
- Nikon’s Optical VR Image Stabilization compensates for the effects of camera shake by moving the image sensor.
This produces clearer, sharper results in lower lighting or unsteady conditions.
- Motion Detection automatically detects moving subjects and adjusts the shutter speed and the ISO setting to
compensate for camera shake and subject movement.
- High ISO 6400 capability gives you sharper results when shooting in low light or capturing fast-moving subjects.
This creates new opportunities to take sharper, more natural-looking photos in lower light conditions.
ISO 3200 and 6400 are available at 3MP or lower resolution.
- Nikon’s original Best Shot Selector (BSS) automatically takes up to 10 shots while the shutter is pressed and
then saves the sharpest image.
• Program, Shutter Priority, Aperture Priority and Manual Exposure Modes give you ultimate control over your pictures.
The D-SLR-type mode dial on the top of the camera provides quick access to greater personal and creative control. Now,
you can adjust the camera’s settings for any type of light conditions and get as creative as you want!
• New Sports Continuous Scene Mode for shooting at up to 15fps, up to 45 frames, when you set the resolution to 3MP
or lower. These high-speed capture settings help you stay ahead of the action. Whether it is a swift golf or baseball
swing, or the fast action on the soccer field, at 15fps you will capture that action.
• Nikon’s Smart Portrait System:
- In-Camera Red-Eye Fix™ automatically fixes most instances of red-eye in the camera. You may never see red-eye again.
- Face-Priority AF is Nikon’s face-finding technology that automatically focuses on up to 12 faces in a group portrait.
- Smile Mode automatically releases the shutter when your subject smiles. The camera will detect the subject's smile
and automatically fire the shutter.
- Blink Warning displays a warning message should the camera detect your subject has blinked.
- D-Lighting rescues dark or backlit images by improving brightness and detail where needed.
• Available Color: Matte Black
Main Features:
• 24x Zoom-NIKKOR lens with focal range from 26mm wide-angle to 624mm super-telephoto
• 3-in. vari-angle LCD with anti-reflection coating for greater framing freedom
• 12.1 effective megapixels for high-resolution images
• Image sensor shift VR image stabilization
• Motion Detection for sharp, steady results
• Advanced shooting modes including Programmed Auto [P], Shutter priority Auto
• High Sensitivity up to ISO 6400*1
• Sport Continuous Mode enables shooting at up to 45 consecutive pictures*2 at 15 fps
• Pre-shooting Cache option enables recording up to 10 frames just before releasing the shutter
• Scene Auto Selector provides quick, carefree picture-taking in a variety of situations
• Optimize image (including monochrome filter effect)
• Distortion Control
• Smart Portrait System – Face-priority AF, Smile Timer, Blink Warning, Blink Proof and In-Camera Red-Eye Fix
• Quick Retouch for the best balance of contrast and saturation
• Active D-Lighting adds detail and optimizes exposure to rescue underexposed images while shooting
Specifications:
• Effective pixels: 12.1 million.
• Image sensor: 1/2.33-in. CCD total pixels: approx. 12.7 million
• Lens: 24x Zoom-NIKKOR; 4.6-110.4mm (35mm [135] format picture angle: 26-624mm); f/2.8-5; Digital zoom: up to 4x (35mm [135] format picture angle: 2496mm).
• Focus range (from lens): 50cm (1 ft. 8 in.) to infinity (∞), Macro close-up mode: 1cm (0.4 in.) to infinity (∞).
• Monitor: 3-in., approx. 230k-dot, vari-angle TFT LCD with anti-reflection coating, Electronic Viewfinder, 0.24-in., approx. 230k-dot.
• Storage media: Internal memory (approx. 47 MB), SD/SDHC memory cards.
• Image size (pixels): 4000 x 3000 (12M), 3264 x 2448 (8M), 2592 x 1944 (5M), 2048 x 1536 (3M), 1600 x 1200 (2M), 1280 x 960 (1M), 1024×768 (PC), 640 x 480 (TV), 3984 x 2656 (3:2), 3968 x 2232 (16:9), 2992 x 2992 (1:1), 1920 x 1080 (16:9: 2M).
• Vibration Reduction (VR): Image sensor shift VR.
• ISO sensitivity: ISO 64, 100, 200, 400, 800, 1600, 3200*2, 6400*2, Auto (auto gain ISO 64-800), High ISO Sensitivity Auto (ISO 64-1600), Fixed range auto (ISO 64-100, 64-200, 64-400).
• Interface: Hi-Speed USB.
• Power sources: Rechargeable Li-ion Battery EN-EL5 (supplied), AC Adapter EH-62A (optional).
• Battery life: Approx. 200 shots with EN-EL5 battery.
• Dimensions (W x H x D): Approx. 114 x 83 x 99 mm (4.5 x 3.3 x 3.9 in.) excluding projections.
• Weight: Approx. 460 g (16.2 oz.) without battery and SD/SDHC memory card.
• Supplied accessories: Rechargeable Li-ion Battery EN-EL5, Battery Charger MH-61, USB Cable UC-E6, Audio Video Cable EG-CP14, Strap AN-CP18, Lens Cap LC-CP19, Software Suite CD-ROM.
• Optional accessories: AC Adapter EH-62A
Image Gallery:
Related Links (PDF):
• Product Brochure [1.13mb]
• Coolpix Comparison [192,7kb]
Links:
• Nikon Official site
• dpreview.com
• LetsGoDigital.org
