Nikon d7000-Firmware update 1.02
Φρα.Πε.
6,844
Ελευσίνα
Εγω τώρα το πήρα χαμπάρι τουλαχιστον και ηδη flashάρω
https://nikoneurope-en.custhelp.com/app/answers/detail/a_id/49208
Βελτιώσεις:
Noise reduction processing is now performed with shutter speeds slower than 1 s (previously 8 s) when On is selected for Long Exp. NR in order to reduce the bright spots that occur with shooting still images at slow shutter speeds.
An issue that prevented the opening of movies recorded with the D7000 in certain movie editing software applications has been resolved.
When the camera was connected to a television via the A/V cable and a movie was played back, playback was normal the first time but when the movie was played two or more times, the sound was played back at extremely low volume and seemed to play intermittently. This issue has been resolved.
When white balance for RAW images created using the camera’s image overlay function was fine tuned with Capture NX 2 or ViewNX 2, the images acquired a magenta cast. This issue has been resolved.
An issue that caused 0.00” to be displayed for heading information when the GP-1 GPS unit was connected to the camera has been resolved so that ---.-- is now displayed.
When Viewfinder virtual horizon was the role assigned to the Fn button or the preview button and the applicable button was pressed, errors in the virtual horizon indicator were displayed. This issue has been resolved.
The following errors in Help displays have been resolved.
- “Maximum sensitivity” help was displayed for shooting menu>ISO sensitivity settings>On or Off help.
- German help displayed “Select focus priority for AF-S mode.” for Custom Settings>a1: AF-C priority selection help
Σκ@τ@... Τίποτα θεαματικό!
Όχι ότι υπάρχει και τίποτα θεαματικό να αλλαχτεί (ή ακόμα και να διορθωθεί!)...
Να βαλω την αναβαθμηση?προτασεις για τα συν και τα πλην αναφορικα με το long exp nr απο 8ς σε 1ς,λαμβανοντας υποψην τις προτροπες του diol οτι η νικον ορθως επραξε,προβληματιζομαι απο τις θεσεις της marianne Oelound http://dpreview.com/forum nikon d3-d1/d700 the sins of the algorithm γινεται αναφορα στην πολυ καλη επιδοση του νεου αισθητηρα και για αστροφωτογραφηση τομεα που υστερουσε η NIKON εναντι της CΑΝΝΟΝ.Παρολη την ερευνα γνωριζοντας την διαφορα του χρονου απο μοντελο σε μοντελο θελω την αποψη σας αν θα πρεπει να κανω αναβαθμηση.
Χαιρετω,δεν εβαλα σωστα το νημα ελπιζω να το διαβασεται εχει μεγαλο ενδιαφερον για τους φιλους της NIKON και οχι μονον.Στην προτελευταια παραγραφο αναφερει (νικον σιωπη)οτι με τις αναβαθμισεις η εταιρια βελτιωσε ακομη το AF σε διαφορα μοντελα χωρις να το πει σε κανενα.Αυτες τις παρατηρησεις ειναι απο την μεγαλη εμπειρια που εχει με διαφορα μοντελα.Πριν λιγο καιρο ηταν προσκεκλημενη στα κεντρικα της νικον μαζι με τον Thom Hogan και με τις παρατηρησεις της βοηθησε στο να βελτιωθει ο καινουργιος αισθητηρας και οχι μονον.Στο νημα λαμβανει μερος ο HOGAN Και ο Iliah Borg τον οποιο εμαθα απο τον Ηλια Γιαριμη. Ελπιζω να παρω μια απαντηση απο τους πιο εμπειρους στην πολυ δυσκολη ερωτηση που εθεσα αν και φαινομενικα απλη.forums.dpreview.com/forums/read.asp/forum=1021&message=34325771
