PECIFICATIONS:
General
Type : Integrated amplifier
Power (FTC) / 20Hz – 20kHz, 8 ohms, both channels driven : 2 x 150W @ 8 ohms/2 x 300W @ 4 ohms
High Instantaneous Current Capability (HCC) : ±100 Amps
Ultrawide Bandwidth @ 1W (+0, –3dB) : 10Hz – 170kHz
Discrete Amplifier Output Devices : Yes
Signal-to-Noise Ratio (IHF-A) : 109dB
EzSet : EzSet/EQ™, 2.2-channel
Audio Inputs : 8
Tape Monitor Loop : Yes
Phono Input : Yes, MM and MC
Digital Audio Inputs : Rear panel:
2x coax
2x optical
Processor Input : Yes, 2.2-channel
Balanced XLR Inputs : Yes
HRS Link : Yes
Digital Audio Outputs (Coax/Optical) : Rear panel 1/0
Preamp Outputs : Yes
Subwoofer Output : Yes, dual
Power Requirement : AC 220V – 240V/50Hz
Power Consumption : 800W max
IR In/Out Jacks : Yes
Dimensions (H x W x D) : 165mm x 440mm x 435mm
Weight : 19.6kg
Copy Paste αλλά βγαίνει κάποια άκρη
