Ο πολεμος ξεκινησε...
Yperion
21 June 2006
43,473
BVR (Beyond Visual Range)
Sharp to kick off LCD price war
This Christmas, Sharp is going to hunt down its enemies.
Last year, the Japanese electronics giant lost some footing in the LCD TV market, in part because its rivals had moved to a different standard of manufacturing that allowed them to release cheaper, bigger sets.
Those days are over, one Sharp employee told me. The company is already making TVs out of glass from its eighth-generation Kameyama plant. The sheets of glass from this plant measure 2.16m by 2.46m. Six 52-inch LCDs can be popped out of a single sheet. The smaller glass sheets processed in sixth and seventh generation plants (Sony and Samsung have a seventh generation plant) can only produce two and three 52-inch panels, respectively, out of a single piece of glass.
Christmas pricing will be interesting, the source said.
Earlier in the month at the Ceatec trade show in Japan, Sharp trotted out a 64-inch LCD monitor that provides a resolution that is three times that of normal (HD Ready) high definition. Normal HD screens have 720 lines. The prototype monitor sports a 4,096x2,160-pixel resolution, triple the number of vertical lines (the second figure) to a normal HD screen, and double that of 'Full HD' 1080p resolution.
http://news.cnet.co.uk/televisions/0,39029698,49284453,00.htm
Re: Απάντηση: Ο πολεμος ξεκινησε...
H Sharp αρχιζει πολεμο τιμων για τα Χριστουγεννα και αλλες εταιρειες αναγκαστικα θα ακολουθησουν!!!
Θα γινει χαμος...:slapface:
Παντως εγω πιστευω οτι μετα τα Χριστουγεννα οι τιμες θα ειναι ακομα καλυτερες αφου τα καταστηματα και οι εταιρειες θα αρχισουν να σπρωχνουν οτι εχει μεινει "κοψοχρονια".
Ναι, αλλά δεν γίνετε Άγιος Βασίλης χωρίς νέα τηλεόραση…. :Banane0:
Από την άλλη πιστεύω ότι οι πρόσφορες μετά τα Χριστούγεννα θα είναι μόνο τα Χριστουγεννιάτικα δέντρα… :flipout:
Κακαλιός Στέργιος said:
Είναι ένας πόλεμος που μας αρέσει!
Mεγάλη προσοχή στις αγορές για να μην μας πουλήσουν το κατιμά του Μουντιάλ:ernaehrung004:
Σ'αυτο κανεις λαθος φιλε μου γιατι για παραδειγμα ΜΕΤΑ το μουντιαλ επεσαν οι τιμες. Το κολπο ειναι να αγοραζεις οταν δεν αγοραζουν οι αλλοι, τοτε εχει τις καλες προσφορες.-bye-
Ναι, αλλά το επόμενο μουντιάλ είναι το 2010, σωστά; :Banane0: :ernaehrung004: -bye-
αν η sharp 37'' 1080p πάει 2100 δεν πρέπει να κατεβει και άλλο η amoi που είναι στα 1900?
