Octagon SF8008 4K UHD
manosfk
10 December 2007
131
Καλησπερα σας
Αυτός ο δεκτης με αυτά τα χαρακτηριστικά μπορεί να ανταγωνιστεί τους VU+ DREMABOX ?
The Octagon SF8008 is the second 4K UHD receiver from Octagon. It decodes content in HEVC.265, offers two fixed tuners (DVB-S2x and DVB-C/T2), with 15,000 DMIPS highly conductive and meets the highest standards in terms of connection possibilities. It has a USB 3.0 port as well as a USB 2.0 port, a Gigabit LAN interface, a CA bay, an S/PDIF output, an AV port, an RS-232 as well as an HDMI connection and a microSD card slot.
It supports numerous images and plugins, HDR and HLG.
Technical data Octagon SF8008:
- DVB-S2X & DVB-C/T2 Combo (2xTuner)
- Hisilicon Hi3798MV200 Huawei Chip
Quad core 64 bit (4x 1.6 GHz) processor with 15000 DMIPS
8 GB eMMC flash memory.
1GB DDR4 RAM.
4-digit 7-segment display.
- 300Mbit Wlan built-in, 2x Wlan antennas
Features:
Linux Enigma2 OS operating system.
- DVB-S2X 4K UHD & Multistream
- PIP HD & UHD (image in image)
- HDR 10bit & HLG
Blindscan (blind search).
Kodi support.
- HbbTV
Stalker support.
- ffmpeq HW Playback Support
- 2160P Media Playback H.264 and H.265 HEVC
- OTA updates
PVR recording (*optional)
- 0.5 W stand-by
Connectors:
1 x H.265 HEVC 4K UHD DVB-S2X tuner LNB input.
1x H.265 HEVC HD DVB-C/T2 tuner input
1x Dolby S-PDIF
1 x AV audio video jack to RCA
1 x RS-232 socket (maintenance and service).
2 x antenna
1 x USB 2.0 port.
1 x USB 3.0 port.
1 x HDMI 2.0a output.
1 x Network Gigabit LAN (1000 Mbps)
1 x microSD slot.
1x CA card reader slot
- Recovery reset button
Dimensions: 220 mm x 125 mm x 40 mm.
Box contents:
1 x Octagon SF8008 4K receiver.
1 x remote control.
1 x HDMI cable.
2 x batteries.
1 x power supply (power supply, DC12V-2A)
1 x user manual (German and English).
