OM System ΟΜ-3 , η νέα ρετρό μηχανή της
kbouk
8 January 2010
28,008
ΠΕΙΡΑΙΑΣ
Αύριο ανακοινώνεται , σήμερα διέρευσαν πιο καθαρές φωτό και τα βασικά specs
Here are the specs of the OM-3 leaked by a store (google translated text):
Features:
  • Creative Wheel: 4 color profiles, 4 monochrome profiles, Color Creator and Art Filters
  • Computational photography button: Quick access to 6 calculation photography functions
  • Still, Video and S&Q Video Wheels: Switch between still, video and Slow & Quick Motion video
  • Absolute reliability: IP53 certified weather resistance
  • Professional quality – compact form: Lightweight metal body, 7.5EV In-Body IS (Built-in image stabilization), 20 MP Stacked BSI Live MOS sensor
SENSOR EFFECTIVE RESOLUTION / TYPE 20.4 megapixel 4/3 Stacked BSI Live MOS
PROCESSOR TruePic™ X Dual Quad Core processor
IMAGE STABILIZATION SYSTEM 5-axis image stabilization with up to 7.5 shutter stops of compensation*
DUST REDUCTION Super Sonic Wave Filter
WEATHER PROTECTION Dust, splash and freeze proof (IP53 rated)
VIEWFINDER Eye-level OLED electronic viewfinder, approx. 2.36 million dots
REAR SCREEN 3.0-inch angle screen (electrostatic capacitive touch panel), approx. 1,620,000 dots (3:2)
FOCUSING SYSTEM High-speed Image AF: Image phase detection AF and image contrast AF used in combination
FOCUSING POINTS Cross-type phase detection AF (1,053 points)
AI DETECTION OF Humans, Formula cars, rally cars, motorcycles / Airplanes, helicopters / Express trains, standard trains, steam locomotives / Birds / Dogs, cats
CREATIVE FEATURES Color wheel available Color filter effect: None/8 colors (Red, Orange, Yellow, Yellow-Green, Green, Cyan, Blue, Magenta) with 3 steps Shadow effect: 11 steps (-5 ~ +5) Film grain effect: Off/Low/Medium/High Monochrome color: Normal/Sepia/Blue/Purple/Green *Settings can be saved individually to MONO1/MONO2/MONO3/MONO4. Highlight and Shadow Control settings can also be saved. Color profile control: Saturation of 12 colors can be adjusted in 11 steps (-5 ~ +5) Shadow effect: 11 steps (-5 ~ +5) *Settings can be saved individually to COLOR1/COLOR2/COLOR3/COLOR4. Highlight and Shadow Control settings can also be saved.
CONTINUOUS SHOOTING [Continuous Shooting] approx. 6 frames per second with selectable 1-6 frames per second [Continuous Shooting SH1] approx. 120 frames per second with selectable 30, 60, 100, 120 frames per second [Continuous Shooting SH2] approx. 50 frames per second with selectable 12.5, 16.7, 25, 50 frames per second
WEIGHT Body only: 413 g
DIMENSIONS Approx. 139.3 mm (W) × 88.9 mm (H) × 45.8 mm (D) *Based on CIPA standards: does not include protruding parts
BOX INCLUDES Camera body, CB-USB13 USB cable, Shoulder strap, Instruction manual, Warranty card, BLX-1 Li-ion battery
Το μόνο που με χαλάει φάτσα κάρτα στο όμορφο ρετρό σχέδιο είναι το ΟΜ systems αντί Olympus , βασικός λόγος που κρατώ και ΟΜ1 αντί της ΟΜ1.2 :LOL:
Εξακολουθεί για εμένα προσωπικά η PenF να αποτελεί το πιο όμορφο retro σώμα
Διαρευσαν και οι τιμές στην Αγγλία
  • OM-3 Body £1699
  • OM-3 Kit with 12-45mm F4 Pro £1999
  • 17mm F1.8 II £479
  • 25mm F1.8 II £399
Reactions: Billy the Kid
Η λίρα είναι στα 1.2€ περίπου, άρα 2.042€ συν πλην η διαφορά ΦΠΑ και η πολιτική της αντιπροσωπείας. Ες αύριον τα σπουδαία, ήτοι το λεπτομερές περιεχόμενο...
Μιας και η ΟΜ1.2 ως ναυαρχίδα είχε πέσει και πολύ κάτω από 2000 ευρω θεωρώ ότι η ΟΜ3 πολύ σύντομα θα ολισθησει στην σωστή τιμη της
Θα επαναφέρουν την τιμή της ΟΜ1.2 ψηλά αλλά αυτό θα είναι ένα τέχνασμα για να δικαιολογήσουν την υψηλή τιμή εισαγωγής της ΟΜ3
Οι γνωστές κουτοπονηριές ….
Αύριο ανακοινώνεται , σήμερα διέρευσαν πιο καθαρές φωτό , τις βλέπετε εδώ
  • OM-3 Body £1699
  • 17mm F1.8 II £479
  • 25mm F1.8 II £399
Πέρα από ότι είναι πανέμορφη κάνανε και το ασημένιο να μην φαίνεται ψεύτικο , τέλια απόχρωση !
Έχω κρατήσει την πρώτη αυθεντική αναλογική OLYMPUS OM1...μακάρι να βγάζανε πάλι μια full frame με την ίδια αισθητική και παρομοιους μικρούς φακούς... όνειρο ήταν!
Sent from my 24030PN60G using Tapatalk
Reactions: cacau and Kosh
Καλά θα βολευτουμε με το σαμυαμιδι (σε μεγεθος αισθητηρα) εως τοτε :ROFLMAO:
Διερευσε και το αυριανο ανακοινωθεν στον τυπο
Here is the leaked OM-3 press text:
Powerful performance and image stabilization
Equipped with TruePic X image processor and a 20.37 MP stacked BSI Live MOS sensor, the OM-3 delivers exceptional image quality and maximizes the performance of the M.ZUIKO DIGITAL lens. The 5-axis image stabilization provides up to 6.5 shutter steps with compensation in the center and 5.5 steps at the edges. When used with the compatible lens, the camera supports Sync IS, which provides even more powerful image stabilization in steps of up to 7.5 steps in the center and 6.5 steps at the edges. With effective image stabilization, you can capture better images even in difficult conditions and create unique effects with long shutter speeds, even without a tripod.
Profiles for unique artistic expressions
With the customizable color and monochrome profile features, photographers can create unique visual styles and recreate the classic look of film processing. Choose from settings such as “Chrome Film Rich Color” for deep, dynamic tones, “Chrome Film Vivid” for high saturation and rich colors, or “Classic Film B&W film grain effect” for striking black and white images.
Advanced features directly in-camera
The OM-3 features advanced post-processing tools directly in-camera, giving photographers unrivaled creative control. Access features such as High-Res shooting (tripod and handheld), Live ND/GND, HDR, Focus Stacking and Multi Exposure via the intuitive CP button and control dial. Save time and improve your workflow by creating complex effects instantly – without the need for additional software.
Outstanding video features
Optimized for video creators, the OM-3 excels at capturing professional quality video. Easily switch between stills, video and slow/quick motion to customize your creative flow. Achieve cinematic quality with advanced settings tailored for professional storytelling. Record continuously for up to 30 minutes at 40°C or indefinitely at 25°C without the camera overheating.
Αυτό που δεν ήξερα αν θα είχε και το έβαλαν τελικά είναι το GND , δεν το έχω στην πρώτη ΟΜ1 και θα ήταν ο βασικός λόγος να πάω κάποια στιγμή στην ΟΜ1.2. Δεν χρειάζομαι το μεγαλύτερο buffer , ίσα ίσα θα ήθελα την μικρότερη δυνατότητα ριπής που έχει σαν έξτρα ρύθμιση σε SH2 mode , αν το βάλαν και αυτό θα είναι τέλεια
Να τη δω και με το πρόσθετο γκριπ και τελικά τι μπαταρία της έβαλαν για να κλειδωσω το πάτημα στο κουμπί buy now :rolleyes::ROFLMAO:
edit
Άρα μπήκε η μεγάλη μπαταρία της ΟΜ1 και έδωσαν και τις μικρότερες ριπές της ΟΜ1.2 , τέλεια
Το βασικό είναι για μένα τι grip θα δίνουν, πόσο θα κάνει, πως θα κουμπώνει, αν θα χαλάει το design της κλπ, γιατί από αυτά που βλέπω όπως είναι και μακρουλή από πιάσιμο 0.
Υ.Γ. Δεν έβαλαν το Ibis της OM1 αν δεν κάνω λάθος, κράτησαν αυτό που έχει η Om5, ενώ δεν έβαλαν ούτε ένα πιο υψηλής ανάλυσης EVF και μάλλον κράτησαν το ίδιο entry level 2.36 million dots της OM5...βασικά αν ισχύουν αυτά είναι μια OM5 με βελτιωσούλες εδώ και εκει, με ανύπαρκτο grip, άλλα με 2,5Χ την τιμής της ΟM5.
Τόσο κακό evf , με τέτοια τιμή; Κρίμα....
Ας ελπίσουμε να είναι λάθος, γιατί με κόστος 2Κ να δίνεις EVF που το έχει και η κουτσή Μαρία είναι αστείο....ας περιμένουμε βέβαια να βγει αύριο και θα ρίξω θάψιμο μετά!!! Εχω να πω πολλά σε συνάρτηση βέβαια με τα λεφτά που ζητάνε..
Πώς είναι η ΟΜ5 αφού έχει τον νέο stacked αισθητήρα της ΟΜ1 / ΟΜ1.2 ?
Το Ibis της πρώτης ΟΜ1 είναι πάνω κάτω , απλά πλέον δίνουν και προδιαγραφή για τα άκρα πόσο επιροη έχει που μέχρι τώρα δεν υπήρχε στα specs των προηγούμενων μοντέλων
To Ibis της πρώτης OM1 ξεκινάει από τα 7stop, αυτό που δίνουν εδώ είναι της OM5 ξεκάθαρα.
Καλά τώρα stacked αισθητήρας, σιγά την διαφορά που έχουν, στα χαμηλά iso καμία διαφορά και μόνο στα ψηλά έχει κάποια διαφορά και όπως λέει και το Dpreview ''ιt's not a huge improvement though΄΄......ψάχνουμε τρίχες δηλαδή....έτσι και αλλιώς αν κάποιος κυνηγάει την maximum απόδοση σε αισθητηρα, iso κλπ. μπορεί με πολύ λιγότερα από 2Κ να πάρει μηχανή με πολύ καλύτερο αισθητήρα.
Επιμενω σε αυτό που λεω, από αυτά που διάβασα μιλάμε για μια OM5 με άλλο κέλυφος, χωρίς grip, κάποιες έχτρα ευκολίες από την ΟM1 άλλα με τιμή στον θεό, πιο πάνω και από OM2!!!
To μόνο που με ενθουσίασε ότι επιτελους ξαναγύρισαν σε μεταλλικό σώμα από τις τις πλαστικούρες των OM5/Em10IV ...έστω και αργά κατάλαβαν την γκάφα τους και ελπίζω και η επόμενη OM5II να έχει την ίδια κατασκευή.
Αυτά που γράφεις είναι εκτός τόπου και χρόνου φίλε, τίποτε δεν είναι ολοκάθαρο και μην γράφεις τόσο απόλυτα γιατί μας διαβάζουν και άσχετοι.
Ο νέος αισθητήρας δεν έχει καμία σχέση με τον παλιό . Δεν μιλάμε για την αβάντα στα high ISO μονο που όντως υπάρχει στα ψιλά ISO και πιστεύω εδώ θα τον έχουν καλιμπραρει ακόμα καλύτερα τον αισθητήρα.
Το διάβασμα του νέου στακαρισμενου αισθητήρα είναι πολλαπλάσιο και ταχύτατο τόσο σε φωτό όσο και σε βίντεο , αλλη ταχύτητα εστίασης , άλλο σύστημα AF , πολύ πιο ταχύτατες όλες οι ηλεκτρονικές λειτουργίες (Hires, Nd, stacking κλπ), σε φωτο και βίντεο απουσία στρέβλωσης σε ταχύτατα κινούμενα αντικείμενα κλπ. Εχει τρομερά μεγαλύτερο κόστος ο νέος αισθητήρας , αν είχε τον παλιό αισθητήρα θα είχε τελείως άλλη τιμή η μηχανή και εγώ προσωπικά ούτε θα γύριζα να την κοιτάξω.
Το Ibis της ΟΜ1 που έχω ειναι 8 στοπ συνδιαστικά με φακό , αυτής είναι 7.5 stop συνδιαστικά
Οσο πιο μεγάλο το σώμα τόσο μεγαλύτεροι είναι οι ηλεκτρομαγνητες που μπαίνουν και κάνουν καλύτερη δουλειά. Οποτε δεν θα έχει στην πράξη ούτε το Ibis της ΟΜ5 που είναι πιο μικρότερο σώμα , ούτε της ΟΜ1, κάπου ενδιάμεσα αλλά μιλάμε για ψείρες αφου και της μικρής είναι ήδη πολύ καλό. Μιλάμε για το καλύτερο ibis της αγοράς
Το EVF όπως και κάποια άλλα χαρακτηριστικά (πιθανόν το pro capture , buffer δεν ξέρω αν έχει δεύτερη κάρτα κλπ. ) θα την διαχωρίζουν από την ναυαρχίδα. Το EVF εμένα προσωπικά με αφήνει ψιλοαδιαφορο ως ανάλυση αν είναι ταχύτατο . Θα ήθελα να έχει το μεγάλο αλλά προτιμώ όλα τα υπόλοιπα που έχωσε στα specs γιατί ήξερα ότι κάτι θα αφαιρέσει από την μεγάλη.
Περνώ τώρα από αυτό της ΟΜ1 στης PenF και δεν με ξενίζει κάτι. Είναι και της PenF ολοκάθαρο και μια χαρά κάνω τη δουλειά μου. Σπάνια κάνω πλέον manual εστίαση , εκεί όντως ένα σκόπευτρο μεγάλης ανάλυσης είναι must για όποιο αρέσκεται σε χειροκίνητη εστίαση
Βλέπω μια ΟΜ1 πακεταρισμένη σε σώμα ΟΜ5** - είναι μόνο 1,4 εκατοστά πιο μακριά, 4 χιλιοστά πιο ψηλή και 5 πιο στενή σε βάθος - ενώ κατάφεραν να κρατήσουν το ίδιο βάρος*, παρά το μεταλλικό κέλυφος.
Ο βασικός λόγος που κάποια στιγμή θα την αγοράσω - ο τονισμός δικός μου:
"CREATIVE FEATURES Color wheel available Color filter effect: None/8 colors (Red, Orange, Yellow, Yellow-Green, Green, Cyan, Blue, Magenta) with 3 steps Shadow effect: 11 steps (-5 ~ +5) Film grain effect: Off/Low/Medium/High Monochrome color: Normal/Sepia/Blue/Purple/Green *Settings can be saved individually to MONO1/MONO2/MONO3/MONO4. Highlight and Shadow Control settings can also be saved. Color profile control: Saturation of 12 colors can be adjusted in 11 steps (-5 ~ +5) Shadow effect: 11 steps (-5 ~ +5) *Settings can be saved individually to COLOR1/COLOR2/COLOR3/COLOR4. Highlight and Shadow Control settings can also be saved."
*Για την ακρίβεια είναι ένα (1) γραμμάριο ελαφρύτερη... :ROFLMAO:
**edit: χωρέσαν και μια Pen F για να μην έχουμε παράπονο - δύο μηχανές στην τιμή, εχμ... :unsure: της μιάμισυ...
Το EVF όπως και κάποια άλλα χαρακτηριστικά (πιθανόν το pro capture , buffer δεν ξέρω αν έχει δεύτερη κάρτα κλπ. ) θα την διαχωρίζουν από την ναυαρχίδα. Το EVF με αφήνει ψιλοαδιαφορο ως ανάλυση αν είναι ταχύτατο . Περνω τώρα από αυτό της ΟΜ1 στης PenF και δεν με ξενίζει κάτι. Είναι και της PenF ολοκάθαρο και μια χαρά κάνω τη δουλειά μου. Σπάνια κάνω πλέον manual εστίαση , εκεί όντως ένα σκόπευτρο μεγάλης ανάλυσης είναι must για όποιο αρέσκεται σε χειροκίνητη εστίαση
Κώστα έχω δει δείγματα έχω διαβάσει reviews, έχω μιλήσει με φωτογράφους ο ''νέος'' αισθητήρας που αναφέρεις έχει ελάχιστες διαφορές από τον παλιό και οι περισσότερες είναι κάτω από συγκριμένες προυποθέσεις. Είμαι σίγουρος 100% ότι αν σου βάλουν δείγματα από τον παλιό σε σχέση με τον νέο δεν πρόκειται να καταλάβεις καμία διαφορά πουθενά και σε τίποτα. Τα περισσότερα πλεονεκτήματα δε που αναφέρεις δεν είναι του αισθητήρα άλλα του επεξεργαστή, νεών αλγόριθμων κλπ. Σιγά τωρα που δεν θα την κοίταζες, αν είσαι τόσο φανατικός με την απόδοση iso, το AF κλπ. σε σημείο που δεν αντέχεις ουτε για πλάκα τον παλιό 20αρη μάλλον είσαι σε λάθος σύστημα, πάρε καμία FF Sony να δεις τι σημαινει εστίαση, απόδοση αισθητήρα κλπ.
Της penF είναι ολοκάθαρο το σκόπευτρο με τα 2.36 million dots??? Σοβαρά τώρα??? Και μετά λες ότι εγω αυτά που γράφω είναι εκτός τόπου και χρόνου, εντελώς τυχαία όπως πάντα οτιδήποτε δεν είναι καλό σε μηχανή Olympus, υποβαθμίζεις την σημασία του ή δεν το αναφέρεις καν....για το ανύπαρκτο grip που έσκιζες τα ημάτία σου για το πόσο χάλια ήταν η Nikon Zfc και ΖF, δεν είδα να γράψεις κάτι, ή επειδή είναι Olympus μηχανή δεν μας απασχολεί πλέον?
Nαι αλλα εχει θρυλικο ονομα . Για μας τους παλιους χρηστες Olympus η ΟΜ3 ηταν παντα ενας θρυλος.
Και αν κρινω απο την τιμη η μηχανη θα τοποθετηθει ψηλα στην ιεραρχια της εταιρειας.
Καλώς η κακώς η Pen F δεν τους έφερε λεφτά - κακώς για μένα αλλά προφανώς είμαστε μειοψηφία - ενώ οι SLR style πουλάνε καλά, οπότε...
Reactions: kbouk
