Onkyo TX-NR808 πρόβλημα στις εισόδους HDMI
το δικό μου θέμα λύθηκε και χωρίς την διαδικασία του παραπάνω βίντεο.
η διαδικασία είναι η εξής
On the front panel, press 'DISPLAY' and 'STAND BY' to display the main firmware:
i.e. Main 1.07/09723AH then press the arrow button below the 'TONE' or 'LEVEL' button repeatedly to go through the other versions.
When I had no sound DSP was showing "???/????".
After few CLEAR operations sound came up and DSP was showing the proper codes.
το CLEAR γίνεται πατώντας παράλληλα το VCR και το STAND BY στον ενισχυτή, όπως περιγράφετε παρακάτω.
Push and hold VCR and Stand by at the same time.
It will read clear and then set up.
Everything should return back to default and you will need to go back in and set your speakers, EQ and all that stuff back up.
