Onkyo tx-sr 876
svellinis
1 January 2008
1,857
Νομος Αττικης
Πωλειται ενας μαυρος Onkyo tx-sr 876 σε υπερ αριστη κατασταση δουλεμενος παντα σε χαμηλες εντασεις.
Φερει σταμπα thx ultra 2 plus, βαρους 23,3 κιλων και τροφοδοτικο με καταναλωση ρευματος 870 watt, Damping Factor 60 (Front, 1 kHz, 8 Ω), 7 ch × 200 W at 6 ohms, 1 kHz, 1 ch driven (IEC) ρυθμιζομενη αντισταση ηχειων απο 4 Ω-16 Ω.
Υπαρχει η συσκευασια του τιμη 650 Ευρω Τηλεφωνο 6937306752
  • THX Ultra2 Certified with THX Loudness Plus
  • DTS-HD Master Audio™, DTS-HD High Resolution Audio™,Dolby® TrueHD, Dolby® Digital Plus Decoding
  • HDMI™ (Version 1.3a to Support Deep Color™, x.v.Color™, LipSync, Dolby TrueHD, DTS-HD Master Audio, DVD-Audio,and Super Audio CD)
  • VLSC (Vector Linear Shaping Circuitry) for All Channels
  • HDMI Audio and Video Processing (1080p; 4 Inputs and 2 Outputs [Main/Sub])
  • HDMI Video Upscaling (Up to 1080p) with HQV Reon-VX
  • Component Video Upscaling (Up to 1080i)
  • Audyssey MultEQ™ XT to Correct Room Acoustic Problems and to Calibrate Speakers
  • Audyssey Dynamic EQ™ for Loudness Correction
  • Audyssey Dynamic Volume™ to Maintain Optimal Listening Level and Dynamic Range
  • Parallel Push-Pull Amplification Design with Three-Stage Inverted Darlington Circuitry
  • Powered Zone 2 (Audio and Video); Zone 2 and Zone 3 Pre Outs; Independent Control for Volume, Balance (Zone 2 and Zone 3), and Bass/Treble (Zone 2 Only)
  • ISF (Imaging Science Foundation) Video Calibration Function
  • Burr-Brown 192 kHz/24-Bit Audio DACs (PCM1796) for all Channels
  • Three TI (Aureus™) 32-Bit DSP Chips for Advanced Processing
  • Bi-Amping and BTL (Bridged Transless) Capability for Music and Movie Sound Effects
  • Onkyo RIHD (Remote Interactive Over HDMI) for System Control
  • Compatible with RI (Remote Interactive) Dock for the iPod
AUDIO AND VIDEO FEATURES
  • 200 W/Ch Minimum into 6 Ω, 1 kHz, IEC (1 Channel Driven)
  • H.C.P.S. (High Current Power Supply) Massive High Power Transformer
  • WRAT (Wide Range Amplifier Technology)
  • Component Video Switching (3 Inputs and 1 Output)
  • 6 Digital Inputs (3 Optical/3 Coaxial) and 1 Optical Output
  • A-Form Listening Mode Memory
  • Linear Optimum Gain Volume Circuitry
  • Non-Scaling Configuration
  • Tone Control (Bass/Treble) for All Channels
  • Color-Coded 7.1-Multichannel Inputs and Pre Outs
  • Independent Crossover Adjustment for F/C/S/SB (40/50/60/70/80/90/100/120/150/200 Hz)
  • Double Bass Function
  • 6 S-Video Inputs and 2 Outputs
  • 6 Composite Video Inputs and 2 Outputs
  • Front Panel Auxiliary Input (for Camcorders, Game Consoles, etc.)
OTHER FEATURES
  • Music Optimizer to Support Compressed Digital Music Files
  • Theater-Dimensional Virtual Surround Sound Function
  • Newly Designed GUI for System Set-up
  • Neural-THX® Surround Decoder
  • Color-Coded Banana Plug-Compatible Speaker Posts
  • Pure Audio Mode
  • A/V Synchronization Function (Up to 250 ms in 5 ms Steps)
  • 40 FM/AM Radio Presets with RDS
  • RS232 Port
  • IR Input and Output
  • 12 V Trigger
  • 6 A/V Inputs and 1 Output
  • 2 Audio Inputs and 1 Output
  • Phono Input
  • Direct Mode
  • IntelliVolume
  • Late Night Mode (High/Low/Off)
  • Headphone Jack
  • Aluminum Front Panel
  • Preprogrammed RI (Remote Interactive) Learning Remote Control with Macros and Mode-Key LEDs
