Parasound HCA-1000 THX 2-CH Power Amp
asterios syllopoulos
24 June 2006
234
thessaloniki
αψογος 450 ευ
Θεσ/νικη 6945950946
Perhaps the best value in a Home THX Ultra-certified amplifier to be found anywhere. This John Curl-designed amplifier brings out all the subtle details of your music, yet still has the punch for the boldest crescendos and home cinema special-effects explosions. It also features automatic turn-on, making it ideal for home theaters and custom, multi-zone installations.
FEATURES
Circuitry designed by John Curl
THX Ultra-certified
Direct Coupled -- no capacitors or inductors in signal path
Input stage uses hand matched complementary JFETs
12 beta-matched 15 amp, 50 MHz bipolar output transistors
785VA Toroid power transformer with independent secondary windings for each channel, 40,000 µF power supply filter capacitance
Independent power supplies for each channel
DC Servo and relay protection circuits
Highbias Class A/AB operation
AC present, standby/normal, current overload indicators
Tiffany-style RCA input jacks, loop output jacks
12 volt DC automatic turn-on circuitry
Gold-plated 5 way speaker binding posts
Custom designed removable IEC AC cord
Rear mounted gain controls; ground lift switch
2 rack space height front panel
Rack mounting adapter available
SPECIFICATIONS
Continuous Power Output - Stereo:
125 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven;
200 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
Continuous Power Output - Mono:
400 watts RMS, 20 Hz - 20 kHz, 8 Ω
Current Capacity:
45 amperes peak per channel
Slew Rate:
>130 V/µsecond
Power Bandwith:
5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion:
< 0.03% at full power; < 0.01 % typical levels
IM Distortion:
< 0.03 %
TIM:
unmeasurable
Dynamic Headroom:
> 1.5 dB
Interchannel Crosstalk:
> 80 dB at 1 kHz; > 60 dB at 20 kHz
Input Sensitivity:
1 V for 28.28 V, THX Reference Level; 1.1 V for full output
Input Impedance: 33 k Ω
S/N Ratio: > 116 dB, full power; > 96 dB, THX Reference Level
Damping Factor:
> 800 at 20 Hz
Power Consumption:
500 watts
Dimensions:
w 17 1/4" x h 3 1/2" x d 13 1/4", h 4 1/8" with feet
Net Weight:
22 lb
http://www.parasound.com/pdfs/vintage/hca750_1000om.pdf
http://www.parasound.com/pdfs/vintage/hca1000aBrochure.pdf
