- 10 December 2006
- 229
http://www.mad47.dk/skaerm/IMG_2589.jpg
Πωλείται η εν λόγω οθόνη σε άριστη κατάσταση με P-MVA πάνελ 8ms. Είχε αγοραστεί απο mindfactory με επι πληρωμή έλεγχο για καμένα pixel πριν την παράδοση οπότε και δεν έχει.
Στα 100 .
Στα 100 .
LCD panel type 1680 x 1050 pixels, Anti glare polariser, RGB vertical stripe
Panel size 20.1" / 51 cm
Effective viewing area 433.4 x 270.9 mm
Pixel Pitch 0.258 x 0.258 mm
Brightness (nits) 300 nit
Contrast ratio (typical) 800:1
Display colours 16.7 M
Viewing angle - C/R > 10
Viewing Angle (Horizontal) 176 degree
Viewing angle (Vertical) 176 degree
Response time (typical) Eight (black to black) 8 ms
White Chromaticity, 6500K x = 0.313 / y = 0.329
White Chromaticity, 9300K x = 0.283 / y = 0.297
Maximum resolution 1680 x 1050 @ 75Hz
Recommended resolution 1680 x 1050 @ 60Hz
Factory preset modes 15 modes
User definable modes 39 modes
Video dot rate 165 MHz
Horizontal scanning frequency 30 - 93 KHz
Vertical scanning frequency 56 - 85 Hz
sRGB Yes
Aspect ratio 16:10
Connectivity
Signal input Analogue (VGA), DVI-D, PC audio in
Audio output Stereo Audio (3.5 mm jack) 1x
USB USB 2.0
Video sync input signal Composite Sync, Separate sync, Sync on green
Convenience
Built-in audio 2W RMS x 2 stereo speakers
Convenience Enhancements On screen display, SmartManage enabled
Monitor controls Auto, Brightness control, Left / right, Menu (OK), Power on / off, Up / down, Volume control, Input, Size
OSD languages English, French, German, Italian, Simplified Chinese, Spanish
Other Convenience Kensington lock compatible
Plug & Play compatibility DDC/CI, sRGB, Windows 98/ME/2000/XP
Regulatory approvals CE Mark, Energy Star, FCC-B, UL, CSA, SEMKO, TCO '03, TÜV/GS, TÜV Ergo
Swivel +/- 125°
Tilt -5° to 20°
VESA Mount 100 x 100 mm
Dimensions
Depth (with base) 235mm
Height (with base) 423.5mm
Width (with base) 478mm
Height Adjustment range 45mm
MTBF 50,000 hrs
Relative humidity 20% - 80%
Temperature range (Operation) 5° C to 35° C
Temperature range (Storage) -20°C to 60° C
Weight 7.6 kg
