PHILIPS 32PF5331/12 EDID
Orestis_G
19 September 2007
22
Καλησπέρα,
Έχει κανείς την εν λόγω τηλεόραση, με δυνατότητα να τη συνδέσει με DVI -> HDMI στο PC του;
Αν ναι, θα ήθελα την έξοδο από κάποιο (ή και τα δύο) από τα παρακάτω προγράμματα:
Windows
http://www.entechtaiwan.com/util/moninfo.shtm
Linux
read-edid
Ευχαριστώ
Τελικώς το βρήκα εγώ, οπότε για να κλείσω το thread, ορίστε η έξοδος του moninfo:
Monitor
Windows description......... Plug and Play monitor
Manufacturer................ Philips
Plug and Play ID............ PHL4650
Serial number............... I
EDID data source............ I2C bus (real-time)
Manufacture date............ 2005, ISO week 43
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. 710 x 400 mm (~34")
Power management............ Standby
Color characteristics
Display gamma............... 2,20
Red chromaticity............ Rx 0,617 - Ry 0,334
Green chromaticity.......... Gx 0,283 - Gy 0,590
Blue chromaticity........... Bx 0,143 - By 0,086
White point (default)....... Wx 0,284 - Wy 0,295
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... 31-80kHz
Vertical scan range......... 47-85Hz
Video bandwidth............. 140MHz
Extension blocks............ 1
Timing recommendation #1.... 1280x768 at 60Hz
Modeline................ "1280x768" 68,250 1280 1328 1360 1440 768 771 778 790 -hsync -vsync
Timing recommendation #2.... 640x480 at 60Hz
Modeline................ "640x480" 25,180 640 648 744 800 480 482 484 525 -hsync -vsync
Timing recommendation #3.... 720x480 at 60Hz
Modeline................ "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
Timing recommendation #4.... 1280x720 at 60Hz
Modeline................ "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Timing recommendation #5.... 1920x540 at 60Hz
Modeline................ "1920x540" 74,250 1920 2008 2052 2200 540 542 547 562 +hsync +vsync
Timing recommendation #6.... 1920x1080 at 30Hz
Modeline................ "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Timing recommendation #7.... 720x576 at 50Hz
Modeline................ "720x576" 27,000 720 732 796 864 576 581 586 625 -hsync -vsync
Timing recommendation #8.... 1280x720 at 50Hz
Modeline................ "1280x720" 74,250 1280 1720 1760 1980 720 741 746 750 +hsync +vsync
Timing recommendation #9.... 1920x540 at 50Hz
Modeline................ "1920x540" 74,250 1920 2448 2492 2640 540 574 579 562 +hsync +vsync
Timing recommendation #10... 1920x1080 at 25Hz
Modeline................ "1920x1080" 74,250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
Standard timings supported
640 x 360 at 85Hz - VESA
640 x 480 at 60Hz - IBM VGA
640 x 480 at 60Hz - Philips
640 x 480 at 75Hz - VESA
720 x 480 at 60Hz - Philips
720 x 576 at 50Hz - Philips
800 x 450 at 85Hz - VESA
800 x 600 at 60Hz - VESA
800 x 600 at 75Hz - VESA
832 x 624 at 75Hz - Mac II
1024 x 576 at 85Hz - VESA
1024 x 768 at 60Hz - VESA
1024 x 768 at 75Hz - VESA
1152 x 648 at 75Hz - VESA
1280 x 720 at 50Hz - Philips
1280 x 720 at 60Hz - Philips
1280 x 720 at 60Hz - VESA
1280 x 768 at 60Hz - Philips
1920 x 540 at 50Hz - Philips
1920 x 540 at 60Hz - Philips
1920 x 1080 at 25Hz - Philips
1920 x 1080 at 30Hz - Philips
Raw EDID base
00: 00 FF FF FF FF FF FF 00 41 0C 50 46 01 01 01 01
10: 2B 0F 01 03 80 47 28 78 8A 28 8E 9E 55 48 97 24
20: 16 48 4B 25 6A 00 31 D9 45 D9 61 D9 71 CF 81 C0
30: 01 01 01 01 01 01 A9 1A 00 A0 50 00 16 30 30 20
40: 37 00 C4 8E 21 00 00 18 D6 09 80 A0 20 E0 2D 10
50: 08 60 22 00 12 8E 21 08 08 18 8C 0A D0 8A 20 E0
60: 2D 10 10 3E 96 00 C4 8E 21 00 00 18 00 00 00 FD
70: 00 2F 55 1F 50 0E 00 0A 20 20 20 20 20 20 01 04
Raw EDID extension (CEA-861)
00: 02 03 1A 75 47 01 03 04 05 12 93 14 23 09 07 07
10: 83 01 00 00 65 03 0C 00 10 00 01 1D 00 72 51 D0
20: 1E 20 6E 28 55 00 C4 8E 21 00 00 1E 01 1D 80 18
30: 71 1C 16 20 58 2C 25 00 C4 8E 21 00 00 9E 8C 0A
40: D0 90 20 40 31 20 0C 40 55 00 C4 8E 21 00 00 18
50: 01 1D 00 BC 52 D0 1E 20 B8 28 55 40 C4 8E 21 00
60: 00 1E 01 1D 80 D0 72 1C 16 20 10 2C 25 80 C4 8E
70: 21 00 00 9E 00 00 00 FF 00 00 00 00 00 00 00 49
EIA/CEA-861 Information
Revision number............. 3
DTV underscan............... Not supported
Basic audio................. Supported
YCbCr 4:4:4................. Supported
YCbCr 4:2:2................. Supported
Native formats supported.... 5
DTV formats supported....... 7
CE standard timings supported
640 x 480p at 59.94/60Hz (4:3) - Default
720 x 480p at 59.94/60Hz (16:9) - EDTV
1280 x 720p at 59.94/60Hz (16:9) - HDTV
1920 x 1080i at 59.94/60Hz (16:9) - HDTV
720 x 576p at 50Hz (16:9) - EDTV
1280 x 720p at 50Hz (16:9) - HDTV (Native)
1920 x 1080i at 50Hz (16:9) - HDTV
