Η κάποτε κορυφαια philips lcd 32" 32pf9830 με ambilight πωλειται σε τιμη σκότωμα στα 200
specs:
Name Philips 32PF9830
Description 32 inch, Widescreen, LCD, HD Ready, N/A
Built-In Digital TV Tuner / Freeview No
Energy Saving Trust N/A
NTSC Playback Yes
Type LCD
Screen Size 32.0 inches
HDTV Compatible Yes
HD-Ready Yes
1080p24 Support No
Brightness 550 cd/m2
Contrast Ratio 600:1
Full HD (1920x1080) No
Image Enhancement Engine N/A
PiP (Picture in Picture) Yes
Pixel Response Time 8.0 ms
Progressive Scan Yes
Resolution 1366x768
Screen Format Widescreen
Supported Picture Formats 480i, 480p, 575i, 575p, 720p, 1080i
Viewing Angle H/V 176 degrees degrees
Zoom Yes
Speakers Stereo
Speaker Output 3x15 W W
Supported Sound Formats Virtual Dolby Digital
DVI Inputs 1
HDMI Input 1
S-Video Input Yes
Scart Connections 3
Built-In DVD / HDD / VCR No
Dimensions HxWxD 60.5x100x9.6 cm cm
Weight 20.0 kg
specs:
NTSC Playback Yes
Type LCD
HDTV Compatible Yes
HD-Ready Yes
1080p24 Support No
Resolution 1366x768
Zoom Yes
Speakers Stereo
DVI Inputs 1
HDMI Input 1
S-Video Input Yes
Scart Connections 3
Weight 20.0 kg
