Pioneer VSX-2011S
Δημήτρης Θ.
12,626
Πωλείται A/V ραδιοενισχυτής Pioneer VSX-2011S σε πολύ καλή κατάσταση (δεν υπάρχει κουτί, αλλά υπάρχει το manual)
For an all-round, breathtaking sound experience that will take you into the future choose the VSX-D2011-S. At the heart of the high-quality sound production lies the Advanced Direct Energy MOS FET 7-channel equal power amplification (100 W x 7 DIN). The sound is enhanced by the receiver's design, which features a double layered chassis and 3-D Space Frame Construction, as well as 192 kHz/24-bit DACs for top quality reproduction. Clear precision sounds are part of Pioneer's Advanced Multi-channel Stereophonic Philosophy. The Multi-Channel Acoustic Calibration (MCACC)system with microphone monitors your sound environment and automatically adjusts your system to reach the perfect tonal level. To bring the fullest expression to the sound, the VSX-D2011-S also features THX Select, AIR Studios fine-tuning, and an Audio Scaler, which enhances the signals from any digital source to create a smoother, more natural sound. Last but not least: this versatile receiver can handle 96/24 DTS, THX Surround EX/Dolby Digital EX, DTS-ES Discrete 6.1, DTS-NEO:6 and Pro Logic II formats. On top, the Surround modes include Virtual Surround Back. It comes with multiple connectivity options and the 7.1 multi-channel input means that it 's ready for future surround sound formats. And with the learning remote control unit with large LCD, the receiver is easy handled. For ‛regular ' 5.1-channel set-up, VSX-D2011-S can be configured to bi-amp the front left and right speakers, making it the perfect choice for audiophiles and cinephiles alike. The VSX-D2011-S has one USB terminal for connection with PC audio sources.
Τιμή 650
6973376400
πρωτοκυκλοφορησε μαιο του 2002 ως σεπτεμβριο του 03
δεν υπαρχει πια μετονομαστηκε σε ΑΧ5 10/03
ΑΧ5aiS 10/04
ΑΧ4 10/05
ΑΧ4ais 10/6
