Δεν γερασε μεσηλικας ειναι και καλοδιατηρημενος.
Παιζει σχεδον τα παντα απο φορμα με επαρκη ισχυ. Δεν εχει μονο hdmi σε σχεση με τους καινουργιους και video scaler.
THX Select
Power Output VSX-D2011-S
RMS Power (1kHz, 10%THD,
8 Ohm/ch) 120 W
Stereo (DIN) 2 x 100 W (8 Ohm, DIN 1 kHZ THD 1%)
Surround Front 2 x 100 W (8 Ohm, DIN 1 kHZ THD 1%)
Surround Centre 100 W (8 Ohm, DIN 1 kHZ THD 1%)
Rear (Surround) 2 x 100 W (8 Ohm, DIN 1 kHZ THD 1%)
Surround Back 2 x 100 W (8 Ohm, DIN 1 kHZ THD 1%)
Digital Signal Processor
D/A Converter 192 kHZ/24-Bit (one for each CH)
A/D Converter 96 kHz/24-Bit (2-channel)
Audio Scaler Yes
Front L & R Bi-Amplifier Function
Multi-Channel Acoustic Calibration System
Dolby Digital ,Dolby Digital EX / THX Surround EX,DTS, DTS-ES Discrete 6.1 ,
DTS-ES Matrix 6.1 , DTS Neo 6, DTS 96/24,Dolby Pro Logic,Dolby Pro Logic II THX Select
Terminals VSX-D2011-S
USB Yes
Multi-Channel Input 7.1 ch
Digital Input 5 (assign)
Digital Coaxial input 2
Digital Optical input 3 (Front-in incl.)
Digital Output (Optical) 2
Audio/Video Inputs 5/5
Audio/Video Output 2A / 2AV+2V
Phono Input Yes
S-Video Input/Output 5/3
Component Video Input/Output 2/1 (assign)
Preamp Output Yes, All (7.1 ch)
A/V Input on Front Yes
SR (System Remote) Terminal Yes (In/Out)
Speaker A/B Versatile
Large Speaker Terminals Yes (All)
