PIXBOOM Spark High Speed camera
Kosh
7 September 2006
99,947
Εκεί ψηλά.....
Key Specifications and Features​
The Pixboom Spark is equipped with several notable features:
  • Resolution & Frame Rates:
    • 4K at 1000 fps
    • 2K at 1800 fps, with the ability to achieve higher speeds through sensor windowing
  • Sensor:
    • Super 35mm BSI (Back-Side Illuminated) Global Shutter Sensor
    • Designed for high sensitivity and accurate motion capture
  • Recording:
    • Captures in PXBL (Pixboom Raw) format
    • Uses dual proprietary 2X M.2 SSDs (2TB capacity at launch)
    • Unlimited recording duration while storage allows
    • Export options include CinemaDNG and potentially ProRes, via Pixboom’s software
