Πωλειται ενισχυτακι για ακουστικα στο κουτι του χωρις να εχει ανοιχτει ποτε στην τιμη των 20 ευρω και με εξοδα αποστολης του αγοραστη..
Τα χαρακτηριστικα του ειναι τα εξης:
●Easy to carry and use in the outdoors
●New amplifier IC, with high S/N and low distortion
●Individual power switch
●Electronic volume control
●Two sound effects: Flat and bass boost mode
●Built-in Rechargeable battery
●Mini USB charger connector
●With a built-in metal clip
Παρακατω ειναι μερικα reviews για το προιον..
http://www.trustedreviews.com/mp3/review/2009/03/15/FiiO-E5-Headphone-Amplifier/p1
http://www.techenclave.com/reviews-and-previews/review-fiio-e5-headphone-amplifier-141007.html
http://www.pcworld.idg.com.au/review/home_entertainment/fiio/e5/275212
●Output Power:
150mW (16Ω Loaded)
16mW (300Ω Loaded)
●Signal to Noise Ratio:
≥95dB (A weight)
●Distortion:
<0.009% (10mW)
●Frequency Response:
10Hz ~ 100KHz
●Suitable Headphone
Impedance:
16 Ω ~ 300 Ω
●Power Supply:
Rechargeable Li-Ion Battery
●Recharging:
USB 5V DC 400mA
●Size: 44.2x38x12.6mm
●Weight: 30g
