Πωλείται ο πασίγνωστος Pioneer LX-73 AV Receiver σε άριστη κατάσταση. Δίνεται μαζί με το manual, το τηλεκοντρόλ και το μικρόφωνο ρύθμισης του surround.
Τιμή Ευρω 400, συναλλαγή εντός Αττικής
The Pioneer SC-LX73 AV Receiver is ideally suited for the audiophile who accepts no compromise in quality whatsoever. With the Pioneer SCLX73, Pioneer has made it clear to focus on The SC-LX73's performance and construction with this audio visual receiver. The Pioneer SC-LX 73 uses ICE power - Direct Energy HD, an extremely efficient type of amplification, capable of delivering overwhelming power and fast response, it features analogue feedback loops to ensure the signal is free of distortion or interference. The result, unrivalled sound quality.
During the development process of each Air certified product, extensive tuning sessions take place to ensure that the audio playback is so accurate that it would be suitable as a studio-grade monitoring device. Available to download from the Apple App store for free, the Pioneer SC-LX73 can be controlled via intuitive touch screen menus on any iPhone or iPod touch.
The Pioneer SCLX73's MCACC auto calibration system automatically optimises many aspects of the AV Receivers sound settings (using an included microphone) based on the positioning of connected speakers and acoustics of the room environment.
The SC-LX73 also features PQLS Multi-Channel. PQLS is a jitter reduction system that improves the coherence, timing and soundstage of audio playback, it stands for Precision Quartz Lock System. This feature caters for jitter-less multi-channel playback over the HDMI interface.
140 Watts per channel
HDMI v1.4 with 3D
Air Studios sound tuning
Pioneer iControl
PQLS Multi-Channel
Specifications
[TABLE="class: datatable, width: 750"]
[TR]
[TH]Main Features[/TH]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Output Power per Channel[/TD]
[TD]180 W[/TD]
[/TR]
[TR]
[TD]Impedance at Output Level[/TD]
[TD]6Ω[/TD]
[/TR]
[TR]
[TD]Number of Channels[/TD]
[TD]7[/TD]
[/TR]
[TR]
[TD]Signal / Noise Ratio[/TD]
[TD]103 dB[/TD]
[/TR]
[TR]
[TD]Input Connections[/TD]
[TD]β’ 6 x HDMI (1080p upscaling) (1 Front Input)
β’ 4 x Composite In
β’ 3 x Component In
β’ 2 x Coaxial In
β’ 3 x Optical In
β’ 1 x USB / iPod/iPhone
β’ 1 x Ethernet
β’ 1 x Bluetooth adapter port for AS-BT100 (included)[/TD]
[/TR]
[TR]
[TD]Output Connections[/TD]
[TD]β’ 2 x HDMI
β’ 1 x Composite
β’ 1 x Component
β’ 1 x Optical[/TD]
[/TR]
[TR]
[TD]AM/FM Tuner with RDS[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Tuner Pre-set Stations[/TD]
[TD]63[/TD]
[/TR]
[TR]
[TD]HD Audio Formats[/TD]
[TD]Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution[/TD]
[/TR]
[TR]
[TD]Audio Return Channel[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Control with HDMI[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]HDMI Repeater[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]On-Screen Display (GUI)[/TD]
[TD]Easy-to-use GUI, available in English, French, Italian, German, Spanish, Dutch and Russian[/TD]
[/TR]
[TR]
[TD]Internet Radio[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Remote Control[/TD]
[TD]Glow-key, preset remote control (learning)[/TD]
[/TR]
[TR]
[TD]RF Remote[/TD]
[TD]Optional[/TD]
[/TR]
[TR]
[TD]Weight[/TD]
[TD]18,5 kg[/TD]
[/TR]
[TR]
[TD]Dimensions (W x H x D)[/TD]
[TD]420 x 200 x 460 mm[/TD]
[/TR]
[TR]
[TH]Input & Output connections[/TH]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]AV Front Input[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Bi-Amplifier[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Bluetooth Adapter Port[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Component Video Input/Output[/TD]
[TD]3/1 (assignable)[/TD]
[/TR]
[TR]
[TD]Composite Input/Output[/TD]
[TD]4/1[/TD]
[/TR]
[TR]
[TD]Digital Optical Input/Output[/TD]
[/TR]
[TR]
[TD]Digital Coaxial Input/Output[/TD]
[TD]2/- (assignable)[/TD]
[/TR]
[TR]
[TD]Ethernet[/TD]
[TD]1[/TD]
[/TR]
[TR]
[TD]HDMI Input/Output[/TD]
[TD]6 (assignable)/2[/TD]
[/TR]
[TR]
[TD]Headphone[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]IR In/Out[/TD]
[TD]2 in / 1 out[/TD]
[/TR]
[TR]
[TD]Large speaker terminals[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Pre-amp Output[/TD]
[TD]Yes (SW)[/TD]
[/TR]
[TR]
[TD]Speaker A/B[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]USB Host (Front)[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TH]Apple Compatibility[/TH]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Works with iPod[/TD]
[TD]Yes, via digital direct USB connection (included)[/TD]
[/TR]
[TR]
[TD]Works with iPhone[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]iControlAV[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]iPhone Control Button[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Compatible Generations[/TD]
[TD]5th Generation, Nano and above, iPhone (including 3G)[/TD]
[/TR]
[TR]
[TD]Supported Functions[/TD]
[TD]Audio & Video (Video with the supplied iPod/iPhone Video + USB Audio cable), On-Screen Album Art[/TD]
[/TR]
[TR]
[TH]Surround Sound Formats[/TH]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Dolby Digital[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Dolby Digital EX[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Dolby Digital Plus[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Dolby Pro Logic II[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Dolby Pro Logic IIx[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Dolby Pro Logic IIz[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Dolby True HD[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS-ES[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS Neo: 6[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS 96/24[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS-Express[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS-HD High Resolution Audio[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS-HD Master Audio[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]WMA 9 Pro[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]THX Certified[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS Neural Surround[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Surround Modes[/TD]
[TD]13 + 1 (Action, Drama, Sci-Fi, Mono Film, Entertainment Show, Expanded Theater, TV Surround, Advanced Game, Sports, Classical, Rock/Pop, Unplugged, Extended Stereo + Phones Surround)[/TD]
[/TR]
[TR]
[TH]Audio Features[/TH]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Auto Level Control[/TD]
[TD]Yes (Multi-channel)[/TD]
[/TR]
[TR]
[TD]Auto Surround[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Bass/Treble Tone Controls[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Dialogue Enhancement[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Digital Noise Reduction[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Dynamic Range Control[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Front Stage Surround Advance[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Jitter Reduction[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Loudness[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Midnight Listening Mode[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Multizone Function[/TD]
[TD]Yes (3)[/TD]
[/TR]
[TR]
[TD]Phase Control[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]MCACC[/TD]
[TD]Yes (Advanced, 9-band)[/TD]
[/TR]
[TR]
[TD]PQLS[/TD]
[TD]Yes (Multi-channel )[/TD]
[/TR]
[TR]
[TD]Sound Delay (LipSync)[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Advanced Sound Retriever[/TD]
[/TR]
[TR]
[TD]Sound Retriever AIR[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Standing Wave Control[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Stream Direct[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Symmetric EQ[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Virtual Surround Back[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]X-Curve[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TH]Video Features[/TH]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Deep Colour[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]3D Ready[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]x.v.Colour[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]HD Digital Film Direct 24[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TH]Power Output[/TH]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Power output per channel[/TD]
[TD]180W[/TD]
[/TR]
[TR]
[TD]Condition[/TD]
[TD]1kHz, 1% THD, 6Ω[/TD]
[/TR]
[TR]
[TD]Rated Power Output[/TD]
[TD]180W per channel[/TD]
[/TR]
[TR]
[TD]Input (Sensitivity/Imp.): LINE[/TD]
[TD]400 mV / 47 kΩ[/TD]
[/TR]
[TR]
[TD]Frequency Response: LINE[/TD]
[TD]5 Hz - 100 kHz +0/-3 dB[/TD]
[/TR]
[TR]
[TD]Signal-to-Noise Ratio: LINE (DIN)[/TD]
[TD]103 dB[/TD]
[/TR]
[TR]
[TD]Power Requirements[/TD]
[TD]AC 220 - 230 V / 50/60 Hz[/TD]
[/TR]
[TR]
[TD]Power Consumption (in use / standby)[/TD]
[TD]330 W / 0.30 W[/TD]
[/TR]
[TR]
[TH]Construction[/TH]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]AIR Studio Sound Tuning[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]ICEpower[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Pioneer Hybrid Amplification[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Digital Signal Processor[/TD]
[TD]Freescale[/TD]
[/TR]
[TR]
[TH]Amplifier Specifications[/TH]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Direct Energy HD amplifier[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Front L & R Bi-Amplifier Function[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]D/A Converter[/TD]
[TD]192 kHz / 24-bit[/TD]
[/TR]
[TR]
[TD]A/D Converter[/TD]
[/TD]
[/TR]
[/TABLE]
HDMI v1.4 with 3D
Pioneer iControl
PQLS Multi-Channel
Specifications
[TR]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]180 W[/TD]
[/TR]
[TR]
[TD]6Ω[/TD]
[/TR]
[TR]
[TD]7[/TD]
[/TR]
[TR]
[TD]103 dB[/TD]
[/TR]
[TR]
β’ 4 x Composite In
β’ 3 x Component In
β’ 2 x Coaxial In
β’ 3 x Optical In
β’ 1 x Ethernet
[/TR]
[TR]
[TD]β’ 2 x HDMI
β’ 1 x Composite
β’ 1 x Component
β’ 1 x Optical[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]63[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]RF Remote[/TD]
[TD]Optional[/TD]
[/TR]
[TR]
[TD]Weight[/TD]
[TD]18,5 kg[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]4/1[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]Ethernet[/TD]
[TD]1[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]Headphone[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]IR In/Out[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes (SW)[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]iControlAV[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS-ES[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS Neo: 6[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]DTS 96/24[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]WMA 9 Pro[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Loudness[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes (3)[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]MCACC[/TD]
[/TR]
[TR]
[TD]PQLS[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]X-Curve[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]3D Ready[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]x.v.Colour[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]180W[/TD]
[/TR]
[TR]
[TD]Condition[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]103 dB[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]ICEpower[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Freescale[/TD]
[/TR]
[TR]
[TH]SC-LX73[/TH]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
