Πωλείται Προενισχυτής
sangel
149
PBN / SIERRA AUDIO - K2 - Πλήρης διαφορική (XLR) τοπολογία
Σε άριστη κατάσταση.
Custom made in California by Custom House Audio Shop.
Τιμή 2500 ευρώ
Στέλιος
Τηλ. 6977210589
[email protected]
K2 SPECIFICATIONS*
• All-FET circuit design with 375VA transformer
• Fully differential line stage pre-amplifier
• Output XLR 75 Ohms per leg +/-1%
• Input impedance: XLR=10K, RCA=10K
• Gain:= 20dB
• Output Voltage (RMS): Normal= 15VAC
• Employs Dale RN60-D Resistors
• Separate windings for each quadrant in amplifier.
• High-capacity energy storage — 40k uF with capacitance
• Three balanced inputs and two RCA inputs. Balanced, RCA and 75 Ohm BNC outputs for use with PBN’s proprietary impedance-matched interconnect system.
• Features targeted use of special trim Resistors in the vital circuits
• Remote Control for volume and mute
• AC input : 230VAC/115 VAC, a 2Amp/4Amp-250VAC slow blow fuse
• Pre-Amp Dimensions: 19”W x 4.5”H x 15”D
• *MSRP: $5,000 each
*Prices and specs are subject to change without notice
Introducing the new Fully Differential, Mosfet Preamplifier from Sierra Audio. Backed by over thirty years of design experience, testing and critical listening, legendary audio designers Emo Borbely and Peter Noerbaek have created a solid state preamplifier that expands the sonic boundaries of semi-conductor amplification. The engineering staff at Sierra Audio has crafted a line of amplifiers that are esthetically appealing, immensely powerful and above all, musical.
