- 3 August 2006
- 3,273
ΠΩΛΕΙΤΑΙ SONY STR-940B
Παιδια αν ενδιαφερεται κανεις για τον ενισχυτη SONY STR-940B ας επικοινωνησει μαζι μου με pm
Χαρακτηριστικα απο τον κατασκευαστη
Manufacturer's product description
Imagine this: you're enjoying surround sound (using the receiver's built-in decoding) in one room, while your housemate listens to a stereo source (CD, MD, etc.) at the same time in another room. How? The STR-DB940's dual-room/dual-source audio output feeds a shelf system, receiver, amp, or powered speakers in the other room. Borrowing elements of construction and design from Sony's high-end "ES" line, this remarkable receiver lets you enjoy near-ES sound quality while saving a few hundred bucks! Beefy output transistors are mounted in-line on a cast aluminum heat sink for rock-steady multi-channel sound. Oversized "guts", an anti-resonant aluminum front panel, and 110 full-bandwidth-rated watts x 5 channels make for precise, powerful reproduction of Dolby Digital's explosive dynamic peaks! Flip down the 'DB940's front-panel door to reveal a convenient set of A/V inputs plus numerous control buttons; flip the door up for elegant looks in your home theater. Its back panel treats you to a smorgasbord of ins and outs for versatility now and expandability down the road. The 'DB940 is also a DSP dream come true, with separate processors for Sony's exclusive Digital Cinema Sound (32-bit) and for Dolby Digital, DTS, and Pro Logic decoding (24-bit). A learning/multibrand 2-way LCD remote puts control menus, radio station names, and CD titles (from compatible Sony changers) in the palm of your hand! And whether you're feeding digital audio to its 96kHz/24-bit D/A converters, or bypassing all DSP via "analog direct" (great for high-resolution stereo sources like SACD!), you'll experience nothing short of amazing sound.
Equalizer
Equalizer Band Qty: 3 bands
Radio
Type: Radio tuner - AM/FM - digital
Tuning Display: Fluorescent display
Preset Station Qty: 30 preset stations
Antenna Form Factor: Loop AM / wire FM
Station Memo Display: Yes
Auto Preset Memory: Yes
Remote control
Type: Universal remote control - infrared
Supported Devices: TV, VCR, cassette deck, AV receiver, DVD player, CD player, MD player
Features: Macro function, LCD display, learning
Connections
Connector Type:
* 1 x composite video/audio input ( RCA phono x 3 ) - front
* 1 x S-Video input ( 4 pin mini-DIN ) - front
* 1 x headphones ( phone stereo 6.25 mm ) - front
* 7 x speakers output ( banana/spade x 2 ) - rear
* 1 x 5.1 channel audio line-in ( RCA phono x 6 ) - rear
* 1 x 5.1 channel audio line-out ( RCA phono x 6 ) - rear
* 4 x S-Video input ( 4 pin mini-DIN ) - rear
* 2 x S-Video output ( 4 pin mini-DIN ) - rear
* 3 x SPDIF input ( TOSLINK ) - rear
* 1 x SPDIF input ( RCA phono ) - rear
* 1 x SPDIF output ( TOSLINK ) - rear
* 4 x audio input ( RCA phono x 2 ) - rear
* 4 x composite video/audio input ( RCA phono x 3 ) - rear
Τιμη 250 ευρα αν θελετε με 50 ακομα euro σας δινω 1 ζευγαρι ηχειων conrad electronics με 2 subwoofer + 3 tweeter εκαστο (οχι εμποριου αλλα κατασκευασμενο σε καταστημα που συναρμοιλογει ηχεια για καταστηματα - κεφετεριες ντισκοτεκ)
http://www.avclub.gr/forum/attachment.php?attachmentid=31745&d=1226039264
Equalizer
Radio
Remote control
Connections
Connector Type:
