Παιδια αν ενδιαφερεται κανεις για τον ενισχυτη μιας και ερχεται ωσονουπω ο 3900 που παραγγειλα στειλετε pm.
H timh toy 750 EURO μαζι με σετ ηχειων δαπεδου 7.1
Δειτε τα χαρακτηριστικα του
http://www.yamaha.com/yec/products/productdetail.html?CNTID=200003
Yamaha RX-V2600
Audio System
* Sound Output Mode Stereo
* Built-in Decoders DTS-ES Discrete 6.1, Dolby Pro Logic, DTS Neo:6, THX Surround EX decoder, Dolby Pro Logic II, Dolby Digital, DTS decoder, DTS 96/24, Dolby Digital Surround EX, Dolby Pro Logic IIx, DTS-ES Matrix 6.1
* Audio D/A Converter 24bit / 192kHz
* THX certified Yes
* Surround Sound Effects SILENT CINEMA DSP, CINEMA DSP
* Equalizer Yes
* Digital Sound Processor (DSP) Yes
* DSP Preset Qty 22
* Surround System Class 7.1 channel
* Signal-To-Noise Ratio 100 dB
* Output Power / Total 910 Watt
* Input Impedance 47 KOhm
* Input Sensitivity 200 mV
* Total Harmonic Distortion 0.04 %
* Amplifier Output Details 130 Watt - 8 Ohm - THD 0.04 % - 2 channel(s) ( Surround back ), 130 Watt - 8 Ohm - THD 0.04 % - 2 channel(s) ( Center ), 130 Watt - 8 Ohm - THD 0.04 % - 2 channel(s) ( Front ), 130 Watt - 8 Ohm - THD 0.04 % - 2 channel(s) ( Surround )
* Bass Control Yes
* Built-in Display Fluorescent
* Additional Features Bi-Amplifying, THX Select2 certified, A-B speaker switch, On-screen display, Yamaha Parametric Room Acoustic Optimizer (YPAO)
Connections / Cables / Slots
* HD connectors HDMI connection(s) on this receiver make it a great choice for your High-Def home theater. One cable carries digital audio and video data directly to your display.
Connectors
* Headphone Jack Yes
* Coaxial Digital Input Yes
* Optical Digital Input Yes
* Optical Digital Output Yes
Equalizer
* Equalizer type Parametric
Radio
* Type Radio tuner - AM/FM - Digital
* Tuner Frequency Range FM: 87.5 - 108 MHz, AM: 531 - 1611 kHz
* Tuning Display Fluorescent display
* Preset Station Qty 40
* Antenna Form Factor Loop AM / wire FM
* Response Bandwidth 20 - 15000 Hz
* Signal-To-Noise Ratio 70 dB
* Total Harmonic Distortion Mono: 0.2%, stereo: 0.3%
* Auto Preset Memory Yes
Headphones
* Headphones Type None
Microphone
* Type None
Remote Control (2nd)
* Type None
Miscellaneous
* AV Furniture None
Connections
* Connector Type 2 x Digital audio output (optical) - Rear, 1 x 7.1 channel audio line-out ( RCA phono x 8 ) - Rear, 4 x Remote control ( Mini-phone 3.5 mm ) - Rear, 3 x Component video input ( RCA phono x 3 ) - Rear, 1 x Center speaker output ( Banana/spade x 2 ) - Rear, 1 x Audio line-in ( RCA phono x 2 ) - Front, 2 x Surround speakers output ( Banana/spade x 2 ) - Rear, 4 x Audio line-out ( RCA phono x 2 ) - Rear, 1 x FM antenna - Rear, 1 x Component video output ( RCA phono x 3 ) - Rear, 2 x HDMI input ( 19 pin HDMI Type A ) - Rear, 2 x Composite video output (multi zone) ( RCA phono ) - Rear, 1 x Headphones ( Phone stereo 6.25 mm ) - Front, 5 x Composite video input ( RCA phono ) - Rear, 3 x Digital audio input (coaxial) ( RCA phono ) - Rear, 1 x S-Video input ( 4 pin mini-DIN ) - Front, 2 x Speakers output (multi zone) ( Click-fit x 2 ) - Rear, 1 x Serial ( 9 pin D-Sub ) - Rear, 2 x Audio line-out (multi zone) ( RCA phono x 2 ) - Rear, 1 x Composite video input ( RCA phono ) - Front, 4 x Digital audio input (optical) - Rear, 9 x Audio line-in ( RCA phono x 2 ) - Rear, 1 x HDMI output ( 19 pin HDMI Type A ) - Rear, 1 x Digital audio input (optical) - Front, 3 x Composite video output ( RCA phono ) - Rear, 1 x AM antenna ( Click-fit x 2 ) - Rear, 5 x S-Video input ( 4 pin mini-DIN ) - Rear, 1 x 5.1 channel audio line-in ( RCA phono x 6 ) - Rear, 2 x Front speakers output ( Banana/spade x 2 ) - Rear, 3 x S-Video output ( 4 pin mini-DIN ) - Rear
Power
* Power Device Power supply - Internal
* Power AC 230 V ( 50 Hz )
* Power Consumption Operational 500 Watt
* Power Consumption Stand by / Sleep 0.1 Watt
* Power Outlets 2 AC outlets
