Δυστυχώς αλλά λόγω αλλαγής χώρου πουλάω τον DENON AVR-4308 μαζί με ένα σετ ηχείων ROISTER 5.1 .Ο ενισχυτής είναι χρώματος ασημί σε πολύ καλή κατάσταση και στο κουτί του.Τα ηχεία δεν θυμάμαι τι μοντέλο είναι αλλά τα έχω αγοράσει εδώ και αρκετά χρόνια.Τα μπροστινά,το κεντρικό και το sub ειναι ROISTER ενώ τα surround είναι ηχεία monitor με βάση για τοίχο.
Denon AVR4308A
HDMI 1.3a inputs With Video Conversion to HDMI
Audyssey Dynamic Volume and Dynamic EQ
1080p 24/50//60hz & 30, 36 Bit Deep colour, xvYCC colour space pass through
Built in Faroudja FLI-2310 Video Processing with upconversion & Scaling (480p / 576p / 720p / 1080i / 1080p) Dolby True-HD , Dolby Digital Plus and DTS-HD Master Audio decoding ready for Blu-Ray Disc
HDCD Decoding
Simultaneous dual image output via 2 HDMI outputs
Built-in DAB & RDS AM/FM tuner
Upconversion & Scaling to HDMI (High-Definition Multimedia Interface)
Browse Your iPod music/photo collection through the on-screen display using the remote control
Denon "Audio Restorer" for improved sound quality on data reduced audio such as MP3
Ethernet port & Wi-Fi allows music (AAC, FLAC, MP3, WAV, WMA inc. Lossless) files to be played from a remote server
Ethernet port & Wi-Fi connection for multi room options, streaming audio and internet radio
Can be controlled across the internet using a web browser
2 selectable USB inputs (Front & Rear) for direct connection to flash memory drives to listen to music or view photos
32 bit Analog Device SHARC DSP Processors
Automatic 6 Position Audyssey MultEQ XT Setup and Room EQ function with supplied microphone
ALPHA 24 Processing Plus (AL24+) on all channels
7.1 external wide bandwidth (100 kHz) inputs for multi-channel formats, such as DVD-Audio and Super Audio CD
5/7 Channel Stereo
Digitally regulated volume control with .5dB increment adjustments and step range of -80 to +15
Audio Delay/Lip Sync adjustment to match audio signals with video signals (0-200ms)
3 Source, 3 Multizone functionality with Discrete Power, Source Select and Volume control for each zone
Power Amplifier Assign function, lets you assign 2 of the 7 amp channels to drive Zone 2 or 3 speakers directly or Bi-Amp the Front Channels
DENON Link 3rd (Super Audio CD & DVD-Audio) compatible digital input
RS-232C Port for Third Party Control Systems, Remote I/O ports, 2xAssignable 12v triggers
Much improved and redesigned GUI (Graphical User Interface)
Compatible with optional 2-way Denon RC-7000CI / RC-7001RCI RF remote/Control unit
Support for ASD-3W Wi-Fi iPod Dock
Audyssey Dynamic Volume & Audyssey Dynamic EQ
Η τιμή για όλα μαζί είναι 1600 ευρώ.
Ευχαριστώ
Denon AVR4308A
HDCD Decoding
5/7 Channel Stereo
Ευχαριστώ
