Pro-ject phonobox II USB
andreas6670
4 December 2007
120
Εχει δουλεψει 50-60 ωρες, και πωλειται 80 λογω αναβαθμισης ολου του συστηματος
Specifications
Phono MM/MC selection switch located at the rear of the unit
Metal case shields the electronics from vibrational and electromagnetic interference
Small size allows installation close to record player
Special low-noise ICs used
Optimal channel separation through dual-mono circuitry
Gold plated RCA connection sockets
Outboard power supply included
Στειλτε ΠΜ ή τηλεφωνηστε στο 6936666333
