Πιθανότατα κάτι να έχεις κάνει λάθος. Στο manual αναφέρει:
With the product turned off, insert the TX card into the TX Card
Connection (WIRELESS) on the back of the product.
Hold the TX card so that the label "WIRELESS" faces upward and
insert the card into the port.
The TX card enables communication between the product
and the wireless receiver module.
Connect the left and right surround speakers to the wireless
receiver module.
Plug the power cord of the wireless receiver module into the
wall outlet.
Turn on the product. The product and wireless receiver
module will now communicate with each other and you will
hear sound from the Surround speakers.
Έχεις κάνει τα παραπάνω βήματα?
Αν ναι κάνε και το παρακάτω.
If the product doesn't make wireless connection, the system needs ID Setting between the
product and wireless receiver module. With the product turned off, press "0"->"1"->"3"->"5" on the remote control, and then turn on the product. With the wireless receiver module turned on, press the "ID SET" button on the back of the wireless receiver module for 5 seconds.
