PS3 Firmware 2.10 έρχεται...
Translation
A Voice Changer feature has been added to the Voice and Video Chat menu. If you want more information visit eu.playstation.com and consult the "Voice Changer" guide included in the "Help and Technical Assistance for PS3" section.
This feature allows you to change the tone of the sound originated by audio devices, like microphones. It has 5 preset levels and a bass and (what's the opposite of bass? :p) scale.
You can alter the tone while using the Voice and Video chat options available in "Friends"
Other 2.10 stuff
Music
- Now you can select the options [Type 3] in Settings > Music Settings > Bitmapping. This bitmapping process has been designed exclusively for the PS3 with the goal of improving the audio reproduction.
Video
- DivX y VC-1 WMV (WOOOOOT) are now compatible. *
- The system is now compatible with the Profile 1.1 Blu-ray Disc. **
- A [BD data tool] option has been added ***
- To play VC-1 (WMV) files you will need to select the option [Activate WMA reproduction], available in the Settings > System Settings
- It's not possible to play copyrighted files or files compressed with DivX 3.11
- It's not possible to play files bigger then 2GB
- Now you have several additional features, like the simultaneous reproduction of the videos in the Blu-ray Disc compatible with the 1.1 Profile. The available features vary depending on the disc.
Stores the management data used by the Blu-ray Disc.
Οι σημειώσεις με κόκκινα γράμματα είναι από εμένα.
Λίγο μπερδεμένα είναι...θα δούμε σύντομα τι εστί...
ετσι και υποστηριξει και divx 8α ειναι απο τις καλυτερες αγορες το μηχανημα
You are here:/ Help & Support / PS3 / Guides / Update features (ver 2.10)
PLAYSTATION 3 System Software updates
Update features (ver 2.10)Find out what features are included in PS3 system software update 2.10.
An update to the PS3 system software was released on December 18, 2007. If you update your PS3 system, the system software version will be 2.10 and the following features will be updated. In order to download PS3 system software version 2.10, you will need a minimum 120Mb of free space on either the PS3 Hard Disk Drive (System Update) or on removable storage media (PC Update).
The PLAYSTATION 3 system software version 2.10 update includes the following:
Voice Changer
The Voice Changer feature has been added to voice / video chat. Visit the Voice Changer guide in Help & Support under PS3 at eu.playstation.com for more details.
Using this feature, you can change the tone of a voice that is input from an audio device such as a microphone. High and low-pitched tones can each be adjusted to five preset levels. You can vary the tone when using voice / video chat under Friends.
Other new or revised features in version 2.10
Music
You can now select [Type 3] as an option under Settings > [Music Settings] > [Bitmapping]. This bitmapping process was developed specifically for the PS3TM system to enhance audio playback.
Video
DivX and VC-1 (WMV) have been added to the types of files that can be played. *
Blu-ray Disc Profile 1.1 is now supported. **
[BD Data Utility] has been added. ***
- To play VC-1 (WMV) format files, you must go to Settings > [System Settings] and set [Enable WMA Playback].
- Copyright-protected files or files that were encoded by using DivX 3.11 cannot be played. - Files that are 2GB or more cannot be played.
** You may now be able to use several additional features such as playback of two videos at the same time with Profile 1.1-compatible Blu-ray Discs. The available features vary depending on the disc.
*** The management data that is used by the Blu-ray Disc is saved.
Note:
This system software update includes all features contained in previous versions.
The new system software will preserve any settings previously made to the PLAYSTATION 3. Depending on the software title, you may not be able to play without first updating the PS3 system software.
Do not perform updates using any data other than the official update data provided by Sony Computer Entertainment over a network or on disc media, and do not perform updates by methods other than those described in the product documentation or in this site. If an update is performed using data from another source, by another method, or with a PS3 system that has been altered or modified in any way, the PS3 system may not operate properly and may not be able to install the official update data. Any of these actions may void the PS3 system warranty and affect your ability to obtain warranty services and repair services from Sony Computer Entertainment.
Οποτε αυτο που λεει ειναι οτι θα βγει αυριο και οχι σημερα και συνεχιζω μεσα στην σελιδα του PS3 να μην τα βρισκω πουθενα. Μαλλον κοψανε το λινκ. Αντε να δουμε τι θα δουμε...
Nα κανω μια ερωτηση η οποια ισως να ειναι λιγο....:o
Το PS3 υπστηριζει Bitstream μεσω Hdmi?
Δεν ξερω αν το λεω σωστα παντως εννοω αν το Ps3 μπορει να στελνει τον ηχο στον ενισχυτη σε ψηφιακη μορφη και η αποκοδικοποιηση να γινεται απο τον ενισχυτη (που τον χρυσοπληρωσαμε για αυτον τον λογο).
Αν οχι ξερουμε τουλαχιστον αν αυτο μπορει να γινει με καποιο firmware update?
Απάντηση: Re: PS3 Firmware 2.10 έρχεται...
Μια χαρά ερώτηση είναι Αρη μου !
και εγώ αυτό περιμένω αλλά καθώς πάει θα τ αργήσουμε να το δούμε/ακούσουμε :argue:
Υ.Γ. Τι να τον κάνω τον Voice Changer ????
Μας δουλεύουν ??
Σύμφωνα με το manual, από hdmi βγάζει 2, 5.1, 7.1.
Σε όλα αυτά τα format την αποκωδικοποιηση θα την κάνει ο ενισχυτής εφόσον είναι ψηφιακά. whats tha prob?
Σάκη μου άσε το μάνιουαλ και δες στην πράξη.
Ο Αρης και εγώ μιλάμε για bitstream έξοδο Dolby TrueHD & DTS-Master που για την ώρα δεν περνάνε από HDMI..
Το μόνο player αυτή τη στιγμή από blu-ray που το κάνει είναι το καινούριο της Panasonic.
H Toshiba απ την άλλη , το έλυσε το θέμα..-bye-
Δεν έχει βγει ακόμα,παιδιά ηρεμία, ένας ένας.... :smash:
Λογικά θα έρθει αύριο...
Μια ερωτηση....η προηγουμενη εκδοση απο αυτη που αναφερετε στο θεμα , τι νουμερο ειναι ??
Εκανα το βραδι αργα update και σιγουρα ηταν εκδοση 2. Απλα δεν θυμαμαι αν ηταν 2.01 η 2.10 .....
Καλημερα ....
Καλημέρα...!
System Update
Είναι πλέον διαθέσιμο από σήμερα το καινούργιο firmware 2.10.:BDGBGDB55:
(Η προηγούμενη είναι η 2.01 και η ολοκαίνουργια 2.10) -bye-
Downloading update data...
