Remote controls for Vista
Δεβελέκος Στράτος
1,626
Basic remote control for Windows Vista
- Specially designed for Windows Vista MCE new 10’UI
- Refreshing and sophisticated design
- Incorporates Microsoft-recommended RC6 IR protocol
- Up to 45 keys
- WLP Windows Vista Premium ready
- Dimensions: 215mm x 43mm x 32mm
RC1974502/00
Backlight remote control for Windows Vista
- Specially designed for Windows Vista Media Center new 10' UI
- 22 white back-lighted keys
- Up to 45 keys
-Dimensions: 215mm x43mm x 32mm
RC1974603/00
Advanced IR learning backlight remote for Windows Vista
- 23 white back-lighted keys
- TV Standby & Volume Learnable keys
- Up to 46 keys
RC1534522/00
Alternate Remote Control for Windows Vista
- Specially enhanced for Windows Vista Media Center new 10’ UI
- Up to 45 keys
- Dimensions: 192mm x 58mm x 30mm
Localized IME solution for Global Market:
Localization options
- with or without TELETEXT
- language versions include Simplified Chinese, Traditional Chinese, Korean, Russian & others
RC1762401/00
PC Express Card Remote coming soon for Windows Vista
- Dedicated to Notebook / Laptop with Windows Vista MCE
- Up to 24 keys
- Dimensions: 74mm x 54mm x 5mm
Windows VistaBeanbag OVU412000/00
USB IR transceiver coming soon for Windows Vista
- Receiving IR (carrier freq 30kHz to 60kHZ)
- Incorporates Microsoft recommended RC6 IR protocol
- Learning IR
- Support carrier frequencies from 30kHz to 100kHZ
- Transmitting IR (Emitting)
- Supports carrier frequencies from 30kHZ to 100kHZ
- Supports 2 independent IR emitters
- Send and receive IR simultaneously
- System
- Resume from Standby (S1, S3)
- USB 2.0 (full speed) compliant
- Microsoft emulator device compliant
- Works with Windows Vista inbox
Windows Vista Snowflake OVU411000/00
USB IR receiver (input only) coming soon for Windows Vista
- System
Windows VistaBeanBagModule
OVU413000/00
USB IR transceiver module coming soon for Windows Vista
- Small PCB form factor, easy integration*
- Receiving IR (carrier freq 30kHZ to 60kHZ)
- Learning IR Data
- Support carrier frequencies from 30kHZ to 100kHZ
- Transmitting IR Data (Emitting)
- Support 2 independent IR emitters
- System
- Resume from S1, S3, S4**, S5**
*Dimension compatible with Philips Windows XP Beanbag module
** With compatible system board
RF version
RC1974503/00
RF remote & USB RF receiver (input only) coming soon for Windows Vista
- Incorporates Philips RF protocol
- Up to 45 keys
- Works with Philips USB stick RF receiver
- Microsoft HID class compliant
- Dimension RC: 215mm x 43mm x 32mm
IR/RF version
TINO SRM7500/xx
2-Way Remote Control coming soon for Windows Vista
- Navigating & controlling music playback on the remote control LCD without turning on the screen
- Worldwide 2.4GHz RF for 1-way MCE control & 2-way music control
- Universal & Learnable IR with intuitive setup for legacy CE device control
- Windows Vista SideShow(basic device) ready
