Όπως λέει ο τίτλος πωλείτε το Richard Gray's RGPC 1200 C power choke. Μαύρο χρώμα, άριστη κατάσταση, ένα από τα κορυφαία μηχανήματα του είδους του.
Χαρακτηριστικά μπορείτε να διαβάσετε εδώ.
Parallel products
Non-sacrificial surge protection, Noise removal, and High-Current-on-Demand
With Load Impedance matching and High-Current-on-Demand, RGPC's patented Parallel Power Delivery models stabilize and protect current hungry AV equipment , while at the same time reduce Harmonics, Normal Mode Noise and eliminate Inter-system Common Mode Influence and backflow of electrical pollution.
In addition, they always deliver just the right amount of current each piece of gear needs, ensuring optimum audio and video performance. And unlike traditional series line conditioners, our parallel models present no obstacles between the power source and the A/V equipment ensuring the delivery of uncompromised dynamics allowing your products to perform as originally designed.
Build-In Balanced Surge Protection, per UL1449 3rd edition for type 3 locations.
RGPC 1200 Custom
Offers twice the non-sacrificial dual stage surge suppression of a single 400 Pro, 600 S or 600 RM Pro
Two on-board 6,000 Watt parallel chokes provide double the high-current-on-demand while lowering the noise floor an additional 50 percent
Designed for the most demanding home entertainment systems
Rack mountable right out of the box, ships with detachable rack ears
Μια φώτο του (κάτω από το NAS)
Τιμή 1500 .
Parallel products
RGPC 1200 Custom
Τιμή 1500 .
